Souped up yard kart build
Kartin’ kid
None of your business (Aptos CA.)
I cut off the *insert name of the piece that holds the spindles* and well, rust
5C18FE55-8123-40E4-ADC5-D6F48A4B10A4.jpegCF8B35D6-F816-4303-A0B6-679D65E69E69.jpeg079444A1-018B-43E2-86FC-20980D8F111D.jpeg
thankfully it seems to be almost exclusively surface rust and after examining the rest of the pipe that I cut off the metal seems pretty healthy, I guess we won’t know 100% until I strip the paint. how moisture got in there is beyond me 🤷‍♂️.
In order to prevent more moisture from getting in while it’s exposed I made some wooden plugs, doused the inside of the pipe with WD-40 and hammer them in hard
hopefully that will hold
I’d shoot for zero degrees of camber. Sounds like you may not know what exactly camber is. Zero will give you the largest contact pattern.
redflash
don't give up. I found that the helmet matters more than skill. If you can't see the puddle, you'll be lost. My son is a certified welder and will not wear a helmet under $500.00. He's not arrogant, it really is " you get what you pay for" in welding helmets.
Da Flash
Kartin’ kid
Da Flash
I agree. My uncle (the person who taught me to weld) recommend that I upgrade the helmet before anything else
