goflight2
Does this look correct? Little hole is being covered.
The lil hole in carb is vent, the hole in gasket lines up with the groove in the black plate.Does this look correct? Little hole is being covered.
Yeah. When you turn off the engine, it will flash 4-5 times max rpm you just ran.Good?
Lol. You running 35 mph only at 4k. Your butt gonna be hauling the mail, when we get that 7" driven, flywheel, timing, and carb on.4090
Take it off, if the bolt is loose tighten, get back to us.Quick brake question. Where the bolt goes through the frame, it has a small bend that is leaving the bolt at an angle, resulting in the band not lining up with the drum. Any ideas would be welcomed!
Take the nut off,Quick brake question. Where the bolt goes through the frame, it has a small bend that is leaving the bolt at an angle, resulting in the band not lining up with the drum. Any ideas would be welcomed!
That's what I was looking for!!!!!4600
