Newbie Yerf Dog 30032 Need Advice
BrownStainRacing
Inside carb. If bowl overfill, it will be inside carb. You should be fine. Best to check at this point.
BrownStainRacing
Double check gaskets not leaking, air/vacuum leak.
Let run while spraying carb clearner Or brake cleaner around gasket areas. Listen for engine to die.
BrownStainRacing
Pics of throttle assembly.
There's a throttle stop screw, between air box and blower housing. take it out, or back it out farther.
I find a pic for you.
BrownStainRacing
I did. Little better.
You might not be getting full throttle. You will know more when you get that tach/temp gauge on.
I know the pred carbs are crap, but that's ridiculous for a new engine. I've had over 50 on the stand and not seen that yet.
If it's happens again, jus pick the back of the kart up and bounce it off the ground a few times. That's why I was trying to get you to blow air thur it, to get that needle to fall off the seat.
It'll probably not give you any more problems.
Lmk when you get those other parts in.
BrownStainRacing
Ok, figured it out! I put the new torque converter/driver I bought from Amazon on. Holy cow, that did it! Doubled the speed. Easily 35 plus.
thank you again everyone for taking this newbie through the process!
Oh you jus givin 'er a lil tickle 😆 🤣 😂 😹
We havnt even adjusted the governor yet.
Jus wait til you get that flywheel, advanced key, driver springs, open the main jet a bit, and head gasket changed.
You'll be changing to a higher gear, to calm 'er down.
Speaking of gear, what's the teeth count you have now, and driven size???
BrownStainRacing
We need proof!!!!
Black marks on your shop floor will be satisfactory 😆 🤣 😂
