Hey guys, I have a few updates.
1.) CHain
After some struggle, I was finally able to get the chain sized correctly and installed.. I have seen some youtubers refer to a 3/8 slack being ideal when installed, but how do I measure for that? I tried to just leave a little slack.
I have a video here to share that shows a slight bump in one of the links. Think this will cause a problem? Anything I can do to resolve it?
Hopefully, one day someone else will be looking for some tips, and these pics will come in handy on how I added links to get the size I needed. This is how I was able to add the pins back with the chain breaker. Took a lot of patience and going slow to ensure I wasn't bending anything but I was able to add 2 links this way. (I messed up twice in the process of doing a lot of learning!)
2.) Spark Plug
I ended up pulling my spark plug and found it to have (according to
GKS) either Carbon Fouling or Oil Fouling. What should I do and how can I tell them the apart? I don't know what either means. Here's my 2 supporting images. I did replace the plug, but would like to correct the any issue that could be being caused. Oil was changed when I pulled the cart last week.
3.) Driven Pulley
Yesterday, despite not being sure of the chain, I decided to go ahead and continue assembling to attempt in testing out everything. When assembling the driven, I needed 2 spacer washers between the sprocket and bearing to appropriately line the chain up. Then used a spacer after the sprocket and then the driven and then another spacer and the nut. This is where things went wrong. I then grabbed my impact and tapped on it a couple times. Then something metallic fell from the shaft and I stopped puzzled. After inspecting, I found that the little metal ring around the left bearing had popped off and part of the bearing had broken and the rest was inside the shaft mount. I must have tightened down too much so, here's my question: Something else I did wrong? How much torque should I have used to tighten down the outside nut?
I am going to have to use one of the older bearings now.
