The venturi principle described above is exclusive to a closed system, or pipe. Half of this "pipe" is open to the atmosphere, so different rules apply.
Hey Ez,
I've been thinkin' about your comment, a bit more
...&/so, have some "jabberin' ta do"
Because "part" (not half, due to the roadway) of the "pipe" is "open to the atmosphere"
...I guess this situation could be referred to as a "leaky pipe"
I thought (durin' a 'bout of free thought) about the possibility of enclosing part, if not all of the air channels
...to help alleviate this "leakyness"
But/then, thought
...if any effect (like creating a low pressure area) was to occur
...it would occur inside of the enclosed pipe
Would NOT create a pressure difference
...between the air pressure above the racer
...& the air pressure below it
Also/then, thought about how most times when describing air flow
...most folks refer to
the air as having "layers"
So, (again, while in free thought) I was thinkin' that with ~2" of ground clearance
...& an additional ~1" under the front bumper
...basically, there is ~3" of unobstructed air flowing under, the front of the racer
So/now, let's say each of them (3) "layers" are 1" thick or tall
When, them (3) ~1" "layers" of air flow under the front of the racer
...the bottom "layer" still just flows along, mostly unobstructed
...but, them (2) upper "layers" of air encounter the undercar aero feature
Get "funneled" into the air Intake
...compressed in the Throat
...& then, expands as it exits out thru the Tunnels
So/maybe the lower "layer" of air "acts" as an "air curtain"
...to help "seal" the "leaky pipe"
