Diamonite Electrathon America Racer
Should "go" about here
...checkin' the "fit"
The "opening" seems ta "line up"
...about where we need it ta be :thumbsup:
Seems like we need ta do a bit more trimmin'
Back to/on the mold
...& took ~1" off of the bottom edges ;)
After makin' sure of the "fit" of the first "tunnel"
...I did some adjustin' on the "cut out lines"
...then, went ahead & cut out the second "tunnel"
...& then, there were (2) ;)
* Custom shaped ta "hug" the sides of the monocoque
Flipper 'er over (right side up)
...double checked the "fit"
...& worked on/thinkin' about how ta do, the connectin' duct work :unsure:
...AKA "Duals" :2guns:
Made sure the front roll bar still mounts properly
...& "clears" the "tunnel"
Yup, looks good! :thumbsup:
CAD duct work
Looks like the "piece(s)" we would need are ~10" - 12" long
...& ~4 1/2" at the widest part
I'ma thinkin' that the "tunnel" molds may be useful for makin' these "pieces"
Yup, looks like we can get a ~10" - 12" piece off of it
Even the narrowest part of the mold is ~4 1/2"
...& there are still already coated with PVA
So, yea! I ain't gotta make more molds :wai:
An (inverted) view of the "air channels"
Since we added all of this stuff "hangin' down"
...let's make sure everything is nice-n-even with the bottom of the racer :thumbsup:
Air Intake area
Throat area
The Tunnels
Flipped 'er back over
* Notice the "nose" is ~1" higher than the actual floor of the racer
...for even better unobstructed air flow
...into the under car aero system
I put the front wheels on & leveler 'er out
...ta check on ground clearance
Looks like the bottom will "ride" just under 2" off of the ground
On ground clearance, the EA rule book states:
10 WHEELS and TIRES
1. Tires must be a pneumatic (inflatable) type.
2. Wheels and tires of any diameter or width may be used.
3. The minimum ground clearance is to be judged by the cars ability to roll over a 2x2 that is milled to be1½”x1½”.
This is to prevent the vehicle from sliding on the ground in the event of failure of any or all of the tires. (page 8.)
So, we look ta be "in compliance" :thumbsup:
Here is a view of the front ground clearance
...with the wheels on ;)
A view of the air intake area
...from up/underneath
...as it will "ride down the road" :cheers2:
