Diamonite Electrathon America Racer
I added a connector to the Brake Lever/Brake light switch connection
...will be hidden behind the dash
This is so, the Lever is removable from the wiring harness
...& NOT permanently "hard wired" to it ;)
Again, just Plug-n-Play
* Notice, the wire colors are connected (same/same) :thumbsup:
Power wires (AKA Battery Cables)
The Positive (+) & Negative (-) power wire connector, at the Speed Controller
I used some Orange Vinyl tape to "bundle" the power wires together
* Taping tip: try-n-not touch the end of the tape when installing
...as to NOT contaminate or reduce the "stickability" of the "end" of the tape :thumbsup:
On most EV's Orange "wrapping" indicates that they are the "High(er) Voltage" power wires
The Positive "battery cable" goes from the SC to the Circuit Breaker, first (Load)
...then, goes to the Battery pack (Batt)
* I labeled 'em for future reference :cheers2:
Let's discuss Speed Controllers
For this racer, we need a speed controller for a 48V system
...& 1,000W brushed motor
Here is the Yalu Model YL-03 48V 1,000W speed controller
...that came with the motor kit
...but, the label (on it) doesn't have much info
To help explain further
...this WYYS48 is a 48V 1,000W SC (speed controller)
...that I "fried" a whilst back :eek:
...but, the label, on this one, has more info :thumbsup:
Model #: WYYS48
Power: 1,000W (for up to 1,000W motor)
Voltage: 48VDC (for use with 48V systems/battery packs)
Current: 32A (nominal current capacity 32 Amps)
Short Voltage: 42V (controller will "shut off" when the 48V battery pack, gets below ~42V)
Throttle Voltage: 1-4V (controller accepts throttles with a 1V-4V range)
Function: Reverse: (controller has additional Reverse feature)
Production Date: 20220910 (Made on Sept. 10, 2022)
Here is the wiring diagram that came with the kit
These are the big Power Wires
...Red (+) Black (-) are the Battery cables
...& Yellow & Blue are the Motors Power cables
These are the smaller Signal wires
...like Power Lock (On/Off), Throttle, Charger (Battery Charger connection), Brake (switch), Voltage Meter & Brake light(s) :geek:
Also/supplemental, Warning & Instructions
Now, let's discuss the Power Meter (required in the EA handbook)
INSTRUMENTS
The goal of Electrathon is to see how far you can go in an hour. To do that effectively, you will need to know what you vehicle is doing, so instrumentation is essential. Amperage and voltage are the most important things to know. Simple analog gauges will work, but it's hard to see the needle and small numbers when you and they are bouncing around in a race. Digital units (E-Meters) are more expensive, but they are much more precise, easier to read, and will record the data over time, so at the end of a race you can tell the total number of amp or watt hours you've used. Either way, your meter needs to be connected to a shunt, which is a chunk of metal of known resistance that current flows thru.
(page 24.)
I'm using a PZEM-051 power meter
These are the specs on the box :geek:
Type: for DC systems (check)
Model: 051 (check)
Parts: Includes a 100A Shunt (check)
Made in China: ya...ya...whatever :devil2:...for now :innocent:
In the manual there are:
Specification parameters:
1. Working Voltage: 6.5VDC - 100VDC
2. Test voltage: 6.5VDC - 100VDC
3. Rated Power: 100A/1,000W
4. Measurement accuracy: 1.0 grade
Has a wiring diagram printed in the manual
...&/also, right on the back of the meter too ;)
I'ma thinkin' ta probably mount the Shunt
...up/under here
...right next to the battery :thumbsup:
Ju-alla says "Hey that doesn't look like a 100A Shunt"
I'ma says "good eye" :thumbsup:
On top is a PZEM-051 power meter
#2: is a 50A Shunt
#3 is a 100A Shunt
#4 is a 500A Shunt
Well, it seems that Shunts are calibrated by size
The 50A unit is for systems up to ~50A
The 100A unit is for systems up to ~100A
The 500A unit is for systems up to ~500A
* Hence the difference in sizes
...& the difference in the battery cable connection (bolt) sizes too
They are basically interchangeable (as long as the measurement specs are the same)
Yup, all (3) versions are labeled (75mV)
All (3) versions are also labeled (FL-2 0.5)
Since the system, in this racer is under 50A, I figured a 50A Shunt wasa the "better choice"
* Also, from past experience(s), using a Shunt with closely matching specs, seems to produce a bit more accurate info/data :2guns:
So, Ju-alla, that'sa why we B usin' a 50A Shunt :cheers2:
What is a Shunt?
Technically:
A shunt is a device designed to provide a low-impedance path for an electrical current in a circuit. Electrical shunts are used in a wide variety of applications including power distribution systems, electrical measurement systems, automotive and marine applications. In current measurement, a shunt is a resistor of very low but precisely known resistance placed in parallel with a meter, allowing large currents to be measured indirectly via the voltage drop across it.
Basically:
A simple metal component
...wired "in line" with the Negative (-) Battery cable
...with "sense wires" on each side
...that sends info/data to a meter
...which then, displays the info "in real time" on its screen
Again, here is the wiring diagram (in the manual & on the meter)
...that I went off of
I did a drawin' of my own
...on how ta connect 'er :thumbsup:
Also, I want to try-n-keep the wiring of these power meters
...on ALL of my racers consistent
* For easy inter-changeability of parts amoungst different racers
Ta help keep 'em "idiot proof"
...by ALWAYS having them wired "basically" the same :sifone:
So, ta "double check" on the wire colors
...that I used on previously ta wire up my PZEM-051 power meters
...I went back to the build thread for my Sequoia EA racer (~post #430)
https://www.diygokarts.com/community/threads/sequoia-electrathon-racer.48137/
...& found these pics
Backside of the meter
...& Shunt
Upper closer view of the Shunt wireing
Ok, now that we have the wiring "info"
...we can work on gettin' the Shunt "wired up"
I rounded up some wiring "hardware" (terminals)
...the Yellow ones, for the Battery "cables"
...& the Blue ones, for the signal wires
Stripped the ends of the wires
...& doubled 'em up
Signal terminals, installed
Since the Shunt is "basically" a "part of" the Negative battery cable
...I'm gonnsa insulate it (add an insulating cover)
*This 1 3/8" OD Vinyl tube does a pretty good "job"
** Notice I used a straight edge ta "mark a line"?
Split 'er right down the middle
Shunt slides "right in"
...& the wires & cables will just "run" out of the ends
Side view
Here is the Shunt, all wired up
As per the diagram
White wire goes to the P- "signal wire" connecting bolt, on the Shunt
...the Green wire goes to the B- "signal wire" connecting bolt, on the Shunt
...& the Black wire goes to the B- "battery cable" connecting bolt, on the Shunt
* The Red Positive (+) wire & the Black Negative (-) wires "power" the meter
...& the White & Green wires, are the "signal" wires
** The Red Positive (+) wire
...doesn't "go" to the Shunt
...because that "is" the Negative (-) Battery cable
The Red wire can "go" to the positive (+) Battery terminal
...but, the meter will be "on" all of the time
or
The Red wire can "go" to the "Load" side of the Circuit Breaker
...& the meter will only be "on" when the system is powered
or
The Red wire can be connected to the "Indicator/meter" connecting plug, on the SC
...& the meter will only come on when the SC is "switched on"
I like #3 because, when the meter is "on", I know the SC is "on" & the racer is "ready to go" :auto:
Shunt all wired up"
...with "protective cover"
Hey that is a pretty kool lookin' connector, ya got
...ta connect your harness, to the battery pack
What is it? :unsure:
Well, that there, my friend, is a XT90 connector :cool:
They are a bit more HD than the White Molex type connectors
...& for better "contact" & longevity, the terminals are even gold plated :wai:
They have ta be soldered on to the wires/cables
All ready for the procedure
After installation, they look like this :thumbsup:
* Notice, because of the way they are shaped
...they can only be "plugged in" (1) way
They even have the "polarity" marked right on them ;)
Positive (+) side
Negative (-) side
Now, let's get the "brains" & "display" of the PZEM-051 connected
Double checkin'
...& alignin' the wire colors, with the diagram :thumbsup:
The wires connect to the meter by/with these little "gates"
Just untighten the screw & the "gate" drops down/opens
* The (2) "gates" on the left side are "opened"
...& the other (2) gates are closed
Got 'er all connected up, as per the diagram :geek:
The Red "power" wire gets connected to, the pink wire of the "Indicator" plug, on the SC
** The Negative (-) wire, of this plug, is not needed
...because the Negative (-) wire is connected directly to the Shunt (AKA part of the Negative (-) battery cable) ;)
Connectin' the "signal" connections
...from the wiring harness to the SC
And the "motor" connections too
I gots everything connected up
...& even a battery pack too
...so, I'ma thinkin' we B ready for a "test" :wai:
Turned the Circuit Breaker...on
...& then, the On/Off switch...on
Ju-alla she seems ta be "alive" :sifone:
Have you been dealing with this wildfire smoke? It's been awful here in the Detroit area. Can barely go outside. My plant was even filled with it but we still worked 9 hours last 2 days.
This is a great thread, and even if not interested(I am), it will be a great detailed explanation of wiring and fiberglass!
Hey Grizz,
Thanks!
Hopefully its helpful to folks...now
...&/also, helpful for folks for many years...into the future too :thumbsup:
This thread "is" kinda like a step-by-step manual/guide of this racer
...for "future me"
...'cause it explains what I did
...& why I did it ;)
Yup, the smoke has been pretty thick here for the last couple of days too o_O
Make it look really "overcast"
...& the sun looks kinda weird too :confused:
Wiring harness (assembly)
* Before dis-assembly, I marked the plug ends
Roll cage (components)
Under car aero
** Kinda looks like an arrow head ;)
Air Channels
Frontal view
Each Channel would be ~8" at its "mouth
And maybe ~1 1/2" - 2" at its narrowest area
Also, wanna add some re-enforcment "panels" to "bridge" this area
...to strengthen the "nose"
...& they will also, be part of the undercar Aero "air channel system" :thumbsup:
Um...how? :unsure:
I'ma gonna cut 'em out of a fiberglass panel :thumbsup:
Where ya gonna get a FG panel? :unsure::unsure:
I'ma gonna make it :2guns:
Anyone remember this piece of 1/2" MDF
...that I bonded a piece of countertop laminate on to
...ta make one of the first monocoques?
Well, we gonna use it a s a panel maker
...as its nice-n-flat
...& has a nice-n-smooth surface too
Just gotta give 'er a coat of the PVA (barrier cream)
...so, the FG resin doesn't "bond" to it...permanently o_O
This little 4" paint roller makes it so easy (only took like 5 min)
...& because the PVA is water soluble, clean-up is super easy too (also, only took like 5 min)
I have re-used this (1) like 5 times now :cheers2:
Here is the "finish" of the PVA right after application
Then, it starts to "self-level" (looks like this after ~10 min)
Then, after ~30 min, it is almost "smooth as glass"
