Diamonite Electrathon America Racer
After blowin' lots more dust off (of the racer & the work bench too)
...& a couple of wiping's with Acetone (but, not the work bench)
I think "we" B about ready for some paint :wai:(F'in finally) :cheers2:
I taped off the interior (a whole 'nuther project) ;)
...& the "side pipes" too (ta "highlight" them) :2guns:
Do you paint the mold with a thick layer of resin first before you put your soaked mat on it? Using a roller to spread resin will do that also along with aggressively mixing the resin as to introduce air bubbles.
Hey Denny,
Nope, I didn't
I'ma still learnin'
I'll do better next time
I wasa about ta say "F it" I'ma runnin' outta summer :cry:
...but, remember "if ya gonna do something, try-n-do it right" :thumbsup:
...& "this" is F'in' AWFUL o_O
So, I sanded the entire "F'in" thing down...again :huh:
...& then, started-a-fillin' holes
This rear deck area, was really bad...for some reason :unsure:
This is NOT the fun part :mad:
...but, had ta B done :cheers2:
Yea...well...explain that to "my arms" :confused:
In between sanding (reps)
...I cleaned up some small stuff & got 'em painted
Also, marked a "spot", in line with the Spindle Arm, for a "pilot hole"
...for cuttin' the Tie Rod "ports"
...in the "nose" re-enforcement panels
Kinda like this :thumbsup:
After another "round" of sandin'
...I gathered the freshly painted parts
...ta start on assembly :2guns:
IMO this Satan Black paint really gives parts a "factory like" look :cool:
I really like the texture of this resined, cured & painted1708 Bi-Axial FG
Like the flat "panel" I made up
...that these "nose" re-enforcement panels are made outta
It looks really kool
...& isn't abrasive, to the touch :thumbsup:
Rounded up some kool "hardware" for the re-assembly :cool:
...& got (2) "fresh" coats of paint on 'er by darktime :banana:
Another view
Think it looks any better?? :unsure:
This pic is after the first time
This pic is after the second time
* There don't seem to be as many "spots"
...&/or they are not as deep, as they were
Ya know what? :idea2:
...I'ma gonna just call it...a work in progress :sifone:
Workin' on assemblin' sub-assemblies
* Notice the freshly painted parts are laying on a folded-up sheet
...ta help protect the finish durin' assembly
Spindle parts
Caliper bracket mounted on the Spindle
Spindle assembly mounted on the wheel
Then, there were (2)
Tie Rod parts (& supervisor Ducky) :thumbsup:
I got some fine threaded 3/8" nuts (ta use as "Lock" nuts or "Jam" nuts)
One Tie Rod End just gets threaded on, all of the way
On the other end, of the Tie Rod
...the "Jam" nut threads on, right behind the Tie Rod End
Once the steering adjustment/settings are "made"
...just "synch" 'er up, to Tie Rod End
...ta "lock" 'er in place :cheers2:
Looks like this all assembled ;)
Workin' on mountin the front Axle
I wanted to keep the Button Head, bolt heads inside of the cockpit
...but, these nuts are/will be right in the Air Channel
...& may cause problems
I tried flippin' one over
...& yup, that looks more aerodynamic
So, I flipped both of them (or actually all (4) of them)
Hey Ez,
I was thinking, other than driver "feel"
...how would we know "if" this undercar aero "actually" creates any effect? :unsure:
Testing
Maybe do some test runs
...with the under car aero "blocked off"
...then, a few test runs with the under car aero unblocked :thumbsup:
Then, maybe add some "enhancements" like installing some "forward" air guides
...& maybe even, opening up (cutting out) the grille for additional air flow, into the Air Channels ;)
&/or/maybe try :idea2:
Entrainment
The reduction in pressure within the Venturi throat can be harnessed to create suction. This low-pressure zone creates a pressure differential relative to the higher ambient pressure outside the tube, generating a vacuum force.
This suction enables a process known as entrainment.
Entrainment occurs when this low-pressure area is used to draw a secondary fluid into the primary flow stream. By placing a port at the throat, the higher external pressure pushes the secondary fluid into the main tube, where it mixes with the primary flow.
A classic example is a perfume atomizer. When the bulb is squeezed, it forces a jet of air to move at high speed across a small dip tube extending into the liquid perfume. The fast-moving air has a lower pressure than the atmospheric pressure inside the bottle. This pressure difference pushes the perfume up the tube and into the airstream, where it is dispersed as a fine mist.
Maybe try a small bottle of a scented liquid
...or colorful powder
...connected to the Throat via a small tube
Then, if a low pressure area is created (in the Throat) the liquid (or powder) should get drawn into the air flow
...which should send a noticeable scent or visual, out of the Tunnels :2guns:
Steering assembly durin' installation
Inside view
* Them nuts & bolt ends "point" upwards
...& that is the max they can "turn" :thumbsup:
I used a big 'ol washer under the bolts, where they didn't "go thru" the "saddle"
...ta help "spread the load" on the FG
Steering Wheel w/installation tools & hardware
These Button Head bolts have a Black Oxide coating (basically Black primer)
...& "if" used outdoors, I have found that its best ta paint 'em
Yup, Satan Black
...& I even painted the nuts too
...ta "get away from" that "Hardware store look" ;)
Steering assembly looks like this when, installed
...stuck the seat in too...just ta see :sifone:
Another view
