Diamonite Electrathon America Racer
Now, let's work on the steering wheel/shaft/pitman arm assembly (just mocked up...for now)
Steering wheel settin' on the workbench
...with the pitman arm at the other end
Double checkin' "she" is all squared up
Another view
Inside/under dash view of the installation
* Notice the excess FG cloth
...from bondin' the hood to the monocoque
...hangin' down along the front edge? :oops:
Overall view
Overall view w/steering wheel "flipped" up
Under the "nose" view of lower steering shaft/bushing/pitman arm area
"Next up" the, swing arm
Today we are workin' on
...the motor mountin' plate
...& sprocket alignment
The front (drive) sprocket & rear (driven) sprocket have to (MUST) be pretty well aligned...or you WILL have issues
The easiest "way" that I have found to do this is to
..."clip" a straight edge to the rear sprocket
...& then, bring the motor/sprocket "into alignment" :thumbsup:
Lookin' from the other direction
...makin' sure everything "looks good" ;)
Did some markin' (where the motor mounting bolts "go")
...& then, "cut" some "slots" (for chain adjustability) :cornut:
Man, when do find time to work on anything else?!?! Keep up the good work and should be finished in no time. :cheers2:
Hey Grizz,
Thanks my friend :cheers2:
I'ma hopin' ta do at least a first test ride by the fourth of July :thumbsup:
...yea...in (4) days
Yesterday I only towed (2) cars (summer is always the "slow season" for towing)
...a 1968 T-Bird, that broke down
...& a Equinox, from the Toledo Police Impound lot
In between (while "on call") my brother helped me remove the cabs
...off of (2) old Isuzu NPR parts trucks, for scrappin' purposes
We also, cut the longest frame, of the (2), in half
...& then, stacked 'em up for scrappin' on another "load" :2guns:
I also, welded the motor mountin' plate on the swing arm for the racer
Before: (patient all prepped for the procedure)
After: (good-n-solid)
But, then, I took the rest of the day off (~8:00 until bed time)
...& just layed on the couch
...in the AC
"cause it's been soooooooo hot :devil2:
...yesterday was 93* & had a feels like of ~105*
...& today was ~95* with a feels like of ~107*
...&/so, I'ma pretty much "done for the day" today too :surrender:
Have ya ever looked thru this old thread?
...it may be interestin' to ya ;)
https://www.diygokarts.com/community/threads/fresh-truck.40745/
Hey WTR,
Yup, I think so :cheers2:
I gots a 48V 1,000 MY-1020 motor (~1.2HP)
...a 48V 30A Speed Controller
...a 48V 50A Circuit Breaker
...a PZEM-051 power meter
...& a few different 48V Lithium battery packs, ta choose from (& gonna make some more/of my own...too)
So, we should be "good to go"
...just gotta get 'em mounted on the racer
...&/then, connected up :thumbsup:
* Many pics & lots of info...soon to come...on the electronics part(s) ;)
I wasa able to (in between cooldown breaks)
...pretty much finish up the swing arm (mainly made up a chain for it) :thumbsup:
Checked for "functionality"
Then, even got the "bright idea" to weigh it (for scientifical purposes) :geek:
This entire swing arm assembly looks ta weigh ~32 lbs.
* WOW! o_O
IIRC
...that's about as much as, the entire monocoque weighed :confused:
Tidyin' little things up
Like tacking the front axle to the side mounts
...ta "lock" 'em in place
...for good weldin'
...when back on the workbench :thumbsup:
Got the patient, all prepped for the procedure (ta protect the FG)
Before
After
I used a rag ta help kool 'em down
...after the procedure (also, ta protect the FG)
I keep forgetting about your tow service. lol. And yeah, this heat and humidity is my nemesis! The temp here today is 99! My plant felt like 200! lol. In side my garage a cool 92 with a few floor fans blowing. My wife has been in the house working from home this week in the chilly 70's. I'm a garage guy, so I handle the heat, but can't wait for the 80's. And I hate anything above 75. 😂 Bonus is, we are on shut down next week so work for me!!!!! Well, I'm redoing our bathroom and painting the new 10 interior doors I installed over the winter. I'll work in A/C any day!!! And the wife will be happy. :cheers2:
Post a link to that first test ride. :cool:
I got the side brackets welded up good-n-strong
Dis-assembled...everything...for cleanin'
After a good wipe down (w/paint thinner) I gave everything a good coatin' of Satin Black spray paint
Another view
I did these things, durin' the day, on Thursday July 3rd
...& then, we went to the Oregon, Ohio Freedom Fest (~20 miles away)
Ta start celebratin' America's birthday...kinda early
...with some good food, live music & fireworks :wai:
But,
When we got home
...we found that some storms had "blown thru"
...& had knocked some electrical lines down
...& now, the power was out, for our entire neighborhood :ack2:
* The storm/winds also, knocked the "pipe" this stuff wasa hangin' on
...& everything was, on the ground :mad2:
* NOPE, I had NO CLUE there were even gonna be any storms...in the area :huh:
Thursday morning while dis-mantling the "steel parts" off of the monocoque
I "caught" my elbow on some jagged FG along the bottom edge of the "tail" pretty good (bad) :mad:
That wasa the "last straw" (that thing has been irritatin' me for a while)
&/so,
Whilst the paint wasa dryin' on them steel parts
...the "tail" got "banished" from "the team" :eek:
Ta-Da :cheers2:
Also, did some trimmin' along the front wheel wells (for tire clearance) ;)
Then, "rounded" everything "off"
...& sanded, smoothed...pretty much...everything else :cornut:
