Diamonite Electrathon America Racer
How's ducky?
What a suprise homecoming.
How long was the power out?
Hey WTR,
Ducky don't like storms (or fireworks)
...& just hides under the neighbor's motorhome
...until the "coast is clear"
No power for (2) days
...& yup, it was still in the 90's :surrender:
So, on Friday, I still got some stuff done (American ingenuity)
...just had ta do "powerless stuff"
Like, cleanin'/wipin' the monocoque down
Ez suggested bondin' the steel "saddles" to the FG monocoque :cheers2:
I had ~1/4 of a can of the Appliance Epoxy brush-on paint
...& Epoxy "is glue"
&/so
I gave all of the mounting surfaces a good coatin' of "the glue"
...& on the "saddle" area of the monocoque too
Installed 'em while still "tacky"
...w/nuts & bolts
...to "lock 'em in place" :2guns:
Here is an inside view (after installation)
Underside
That’s what you get for painting everything Satian Black. :ROFLMAO:
Hey Denny,
Satian has nothin' ta do with it :confused:
Satan Black paint is just my "go to" for misc parts :thumbsup:
Now, let's look at some of the electronical parts
48V 50A Circuit Breaker
Because this racer will operate on a 48V battery pack/system
...& the Speed Controller has an Amp rating of ~30A (nominal)
...with potentially a peak Amperage of ~40A
...&/so, a 50A breaker should be appropriate :thumbsup:
This component will "serve" as both a resettable fuse
...& a manual "main" power cut-off switch too :cheers2:
Here is the backside (power connections)
...& it MUST be "wired" appropriately
...to function properly :geek:
* The positive (+) cable, from the battery, connects to the "BAT LINE" terminal
...& then, another (+) cable goes from the "AUX LOAD" to the Speed Controller
This is the PZEM-051 Power meter (more on this little "guy"...later) ;)
* Also, shown (in the first pic) is the Thumb Throttle
...& a hand brake lever (with a brake light switch)
Workin' on "dash "lay-out" ideas (doesn't require any power)
* The EA rules stipulate:
12 ELECTRICAL SYSTEM
1. A fuse or circuit breaker is required in any electrical circuit between the battery and any electrical device.
2. All fuses or circuit breakers should be mounted as close as practically possible to the source of power.
3. All fuses or breakers should be sized to protect the wiring to which they are connected.
The current rating of fuses and breakers shall be no more than those listed in the adjacent table for standard automotive cable.
13 ISOLATION SWITCH
1. An isolation switch (kill switch) is required on all vehicles. This switch must have a break current rating that exceeds the maximum current draw of the vehicle.
2. The switch must be located in the main positive power cable between the battery and any motor controller.
3. An actuator may be attached to the switch for remote operation provided that it is durable and reliable.
4. Means must be provided for both the driver and race officials to actuate an isolation switch.
5. The driver must be able to actuate the switch while in driving position and without reaching outside the vehicle.
6. Race officials must be able to actuate the switch from outside the vehicle without reaching in.
7. Two switches may be installed if necessary.
8. A circuit breaker may be used as the isolation switch.
9. The switch or actuator accessible from outside the vehicle must be mounted within a solid red triangle whose sides are at least 4 inches and in contrast to vehicle color or graphics.
10. Wiring must be well insulated and securely attached to the frame or body. All wiring must be kept free from moving parts and protected from chafing.
11. Wiring that passes through a hole with sharp edges or through sheet metal must be protected by an insulating grommet or other suitable device.
12. Terminals must be secured so they will not come loose or short out during a competition.
13. No part of the electrical system may use the vehicle frame as a conductor. The frame must not be grounded.
(page 9.)
Let's concentrate on these:
So, maybe...
As the driver can easily reach it "without reaching outside the vehicle"
...& race officials can easily reach it "from outside the vehicle without reaching in"
I used a template to mark the required opening
Here's what I'ma thinkin' for the hand brake lever
...but, NOT the power meter
...as the brake lever & the drivers hand would be blockin' the view of it
Side view showing "dash to steering wheel clearance"
Looks like the power meter should be easily seen...on the other side...about here
...& the Speed-o-meter (phone w/app) should be easily seen...about here
I used an Oscillating tool (& a shop vac) ta cut 'er out
I must say, that's a pretty HD dashboard
Here is what the CB looks like when mounted & the On/Off switch too
I got the power meter installed too
...& it looks like this when sittin' in the seat
Speedo should be easily seen about here
Yesterday morning, whilst waitin' for a call, I wasa thinkin', we gotta get the "box" for the battery pack "together"
...remember, it "goes" in front of the seat :thumbsup:
The battery pack(s) I'ma B usin' are ~4" tall
But
The vertical "space" available, from the floorboard up to the front edge of the seat, is only ~2" :unsure:
But
We have ~2" of vertical "space" available, under the floorboard ;)
&/so,
I'ma thinkin' we can incorporate some of the undercar aero (discussed earlier) at the same time :cheers2:
Isa steps up
with a marker & ruler(s) & such
Looks around cautiously...:oops:
"Rounded up" some of the extra 1/4" & 1/2" MDF, from earlier mold makin' projects
...cut 'em up (inta shape)
Made up a custom "plug mold"
...right there "in place"
...& right there "on the spot"
Glued together, side weighted & gravity clamped ;)
An (aerial) view :thumbsup:
A couple of hours later
...& after doin' a couple of "tows"
...it wasa good-n-dry
So, I did some bodywork
Another view
Also, did some custom fittin' to the monocoque
All ready for paintin' :2guns:
* Yup, Denny...I'ma B usin' Satan Black :devil2:
But,
Oddly enough
...I didn't get a pic :innocent:
After the paint dried (overnight)
...I sanded the "plug" (ta smooth it)
...wiped 'er down (ta clean it)
...& gave 'er a good coat of the PVA (barrier cream)
Whilst that wasa dryin' I started ta re-assemble the rear wheel
* Yup, I'ma still tryin'/usin' the plastic/nylon wheel, in the rear
...&/so, we'll "see how it goes"...together ;)
I'ma usin' (switchin' over to) Loc-nuts
...&/so, shiz is "gettin' real"
Sprocket & Sprag Gear...installed
Aired up ta ~30psi
...& all ready ta go :thumbsup:
steel wheels work without a mile of runout?
So steel up front, plastic rear?
with a lot of patience and some shims maybe ya can get the rotor/sprocket
trued up?
trued up?
Hey T,
Yup, the steel wheels seem ta be much "truer" (did ya see the video?) :unsure:
So, yup the steel wheels (usin' some of your "custom made" hubs) in the front
...& the plastic wheel in the rear
This way I can use the Sprag (freewheel unit) & sprocket
...that uses your custom made/kool azz Sprag/Sprocket mount :thumbsup:
A layer of CSM
...a layer of 1708
...& another layer of CSM
...&/then, another layer of 1708
Gettin' ready ta "pop" 'er off :thumbsup:
I wasa gonna/tryin ta use the excess FG hangin' off the sides
...for, attachin' the "piece" to the monocoque
But
Some of the resin hardened along the bottom edge
...so, that "didn't work out so well" :(
So
All excess trimmed off
Since the FG on the monocoque has cured for well over a month
...it needed ta be "roughed up" (technical term) a bit
...& some 80 grit did the job "real well" ;)
Double checkin' "the fit" (before installation)
Looks good-n-tight ta me
* Notice the "alignment guide likes/marks"? They help with final alignment :cool:
I used the same "goopy flap" mounting technique
...ta mount the "piece" (from the inside)
Then, sealed around the perimeter with a layer of CSM
...& a layer of the 1708 too :sifone:
Another (aerial) view
We (me & Ducky) B thinkin' about, how ta do, the roll cage :unsure:
Here are the EA rules/requirements
4 ROLLBAR
1. The roll bar must protect the driver's head/helmet in the event of a roll-over. It must be tall and wide enough to do this considering the full range of possible movement.
2. The roll bar structure must be triangulated with at least three legs or panel equivalent. Triangulated bracing can be either forward or rearward. With three legs bracing must extend from the top of the roll bar and securely attach to the vehicle structure, with four legs, each of the braces must extend to within 4" of the top. Any roll bar that is constructed from more than one continuous piece must be reinforced and braced triangularly from all junctions/joints in addition to the top.
3. The roll bar structure must appear to be sturdy enough to withstand the vehicle being dropped, upside down, from an altitude of one foot, with the driver inside without failure.
4. The driver’s helmet must be below a straight line drawn from the top of the roll bar to the top of the highest structural point when the driver is securely belted in driving position.
5. Composite or monocoque vehicles with integral rollover protection must meet comparable strength and clearance requirements.
(page 6.)
I made these "bars" up last winter, when I wasa workin' on/makin' the wooden model ;)
Hmmm...they B kinda WIDE
...at the bottom
Gonna have ta do/make some modifications
Modifyin'
Test fittin'
* Gettin' closer :thumbsup:
That's a lookin' better
...but, it'sa still not mountable...just yet
Yup, had ta drill some mounting "holes" in the monocoque
More modifications
That's a lookin' even better
A closer view
A view from the rear
Remember this requirement? (in the official EA rulebook)
Also, I found this requirement in the (Challange USA Electrathon America rule book) (a "spin off" group/racing series)
https://drive.google.com/file/d/1cDjMZcp4BsGgtfmRbcjgLae6jw9gvBzi/view
3. The roll cage will consist of two continuous loops that begin and finish at the base of the
chassis and may be either longitudinal or transverse in configuration, with cross bracing
between the loops to connect the two, centered over/above the driver’s helmet.
a. The roll bar must be braced to the chassis, forward and rearward. The rearward
brace will be no more than six inches vertically from the top of the roll bar. The
forward bracing shall form a protective cage around the driver and be designed to
protect the driver from front and side impact
b. Frontal and side driver protection is determined by drawing a straight line
horizontally across the roll cage frame members in front of and to the side of the
driver’s head. The straight line should be a minimum of two inches from the
driver’s helmet
So, maybe...:unsure:
Another view ;)
A view from the front :thumbsup:
I added some Roll Cage mount bracing
I'ma tryin' ta make 'er good-n-strong
...but/also, tryin' ta keep 'er simple (& light) ;)
The upper "cross bar" re-enforces the rear roll bar's upper mounting "points"
...which also, "go thru" the "saddle"
The lower "cross bar" re-enforces the rear roll bar's lower mounting "points"
...which also, "go thru" the "saddle" too :thumbsup:
The lower "cross bar" also, "wraps around" the sides
...ta re-enforce the front roll bar's upper mounting "points"
I could add more...& more...& more
...but... :huh:
Wadda ya's think??? :unsure:
Kinda like this :unsure:
Another "cross bar" that "wraps around"
...& connects to the front roll bars lower "leg"
...or just a short connector/bridge to this "existing" bolt
But, NO I'ma gonna just "see" how this does...for now :oops:
I did make up & install a top (Dingo style) roll bar connector
* Here I'ma workin' on centerin' it (w/a DIY Plumb Bob) :thumbsup:
Side view after installation
...& startin' on the wirein' :)
Wiring
We gots some stranded 10g Primary wire
...Red for the Positive (+) & Black for the Negative (-)
...for the Power wires or battery "cables"
Some 22g-4 wire (4 individual 22g wires)
...for the Signal wires
Some Grommets to "cushion" the sharp edges of the access holes in the FG
FG is electrically conductive (like fiber optic cables)
...&/so, the Grommets also "act" as electrical insulators too
The first signal circuits, that we are gonna work on
...are for the On/Off switch (AKA Power Locks)
...& for the Brake Lever switch (AKA Brake)
Since the Brake Lever wires are Red & Black
...I'ma gonna use the Red & Black wires, in the 22-4 cable, to connect them
Then, I'll use the Green & White wires, in the 22-4 cable, to connect the On/Off switch
I think I'ma gonna mount the Speed Controller about here
...with the wiring harness "running" up/under here
* The steel "saddle" should act as a "heat sink" to help "draw" heat away from the SC :thumbsup:
Now, let's work on the "signal" wires/connections on this "end"
* Remember the Power Lock connector
...is where the On/Off switch connects ;)
This 22g wire is so thin that I usually "strip" a bit extra of the coverin' off
...& bend the wire over/"double" it up
...so, there is more wire/material, for the terminal to "grip on"
Terminal installed on the White 22g wire
Here are both of the On/Off (AKA Power Lock) switch terminals, w/wires
...installed on the harness, in the "mating" connector
After assembly it's simply Plug-n-Play :2guns:
For the Brake circuit
...there are (2) connecting "plugs"
The connector labeled "Brake"
...is where the switch for the Brake Lever connects
* This circuit is NOT polarity sensitive
...as it is just for a switch that "closes" a circuit
The connector labeled "Brake Light"
...is where ya connect the harness (not yet made) for the Brake light
* This circuit IS polarity sensitive
...as it actually "powers" the Brake Light
Usually Red = Positive (+) & Yellow = Negative (-)
...but, always "best" ta "double check"
** Also, since this is a 48V system
...the Brake light(s) have to be 48V compatible :geek:
Like (4) 12V lights wired together "in series" :cheers2:
