Shop Our Other Brake Parts
Shop All Our Parts
Metal Brake or Throttle Rod
Can Be Used For Both Applications
This is a 41in. brake rod, one 1/4in. clevis and pin plus cotter pin and tinnerman nut. Use this kit to connect the brake pedal directly to the braking system -- usually a band brake.
The brake rod is used in place of cable. It provides a solid braking system.
110% Lowest Price Guaranteed!
Brake rod is a good solution when you are able to design for the size of the brake rod. But if the rod is too long or too short, you may be forced to use the rod with cable, or just use cable.
You can use rod for the throttle, too. Often you hook up the rod to a mount near the engine where throttle cable completes the system.
