'wittle 'wesistor (Mini Jeep)
Foam Test
I've made many kart seats using Wal-Mart "seat foam"
...but, I've also, noticed that it doesn't seem to actually provide much support
...& most times (when sitting/riding) you can still feel the wooden platform, under the foam
Automotive seat foam seems denser or seems ta provide better "butt support" :wai:
So, I did a quick test using ~2" of each kind of foam
Left - Wall-mart foam
Right - Automotive seat foam
I added a 1" x 3" x 3" steel weight to each sample
...& both samples seemed to support the weight pretty well :thumbsup:
Then, I added another steel weight, to each sample
The Wal-mart foam quickly "failed"
...but, the Automotive foam still supported the additional weight, pretty well :)
* Not really scientific or nuthin'
...just a quick "backyard" test or demonstration of the (2) different kind of seat foams :cheers2:
Workin' on the seats
After figurin' placment, I trimmed the foam down to the same size as the plywood base
Then, I trimmed the upholstery around the perimeter of the "base", leaving 3"-4" for the wrap around
...& marked & cut the center, of the "corners"
Then, trimmed the corners a bit more
Folded 'er inside out
...& then, pinched the (2) pieces together, for sewing
A couple of "clips" help holdin' 'er together
Use real upholstery thread (if you want it to last for a while) ;)
Had ta take a break, for a surprise inspection, before sewing them corners up
After sewing the corners up, it should, kinda look like an inverted bowl :thumbsup:
After sewing, turn the piece so the inside, is back on the inside
Fold the edges of the upholstery under (for a nice clean look) ;)
...& hold 'er in place for staplin' :thumbsup:
...& then, starta staplin' (just a couple, on each side, at first)
Till, itsa all stapled down good (all of the way around)
I also, tacked the corners for a little additional support, on them DIY seams :)
The first seat bottom turned out like this :wai:
Not perfect
...but, not bad :cheers2:
It's pretty straight
...& I was able to keep/maintain the "groove pattern" :sifone:
The seat backs were a bit more challenging :cornut:
This is kinda the "look" Ima goin' for :)
But, for starters, the seat back, base boards were a bit longer (taller) than the upholstery
So, I made some adjustments (just a little off the top) :thumbsup:
Trimmed the foam to match the base
...& (if/when possible) I left extra material for the "wrap around"
...or add some (if needed)
* It should look like a bowl when done
Rounded the top corners a bit
So, they would look about like this, when done ;)
(1) down & (1) to go :wai:
Hey, what is that spot?
IDK
It's not really a spot of "something" :rolleyes:
It's more like a discoloration :huh:
Maybe something was sitting there (shading the "spot")
...& the sun faded the rest of the area :ack2:
So, maybe the color is just a bit darker there :unsure:
G.W
Nyssa Oregon
You know, the rear seat in a jeep is a bench seat.
But if you want to do it that way I won't judge.
What machine are you using? Those look good, I redid wife's seats in her old race truck, pulled off stock cover ,unstitched the middle part and replaced the pink/black heart and crossbones :thumbsup:
Hey Bansil,
I had to hand stitch these seats because the foam is glued to the fabric
...& the foam gets in the way (keeps catching & causing interruptions in the stitching)
I re-did the seats in one of my trucks, with the upholstery out of a Pontiac Vibe, a couple of years ago
...& used a Brothers sewing machine (Wal-Mart special)
Before
After
Hand sewing wasa killin' my hands
...so, I took a break
...& got (1) of the CAD fenders out & worked on double checkin' the dimensions
Looks pretty close (I must say) :thumbsup:
Then, took 'er back to my workbench ta make some adjustments
...but, Ducky said "I'm already sittin' here" :rolleyes:
I used the CAD fender (with adjustment notes) to make another (V2)
With Duckys help (of course)
She says "You got a problem with that? ...Denny" 🤣
I made V2 ~1" wider (to come out over the tires a bit more)
...plus, I added a ~1" extra (ta bend down & form a rounded edge)
...& made some more "notes" (like how far to extend the bolting flanges)
After a bit of "trimmin'" Ducky says "I think were ready to transfer this to steel" :thumbsup:
We have a 13" x 72" piece left (the spare body side panel, I saved in case I messed one of the original ones up) ;)
...but, getting both fenders out of it wasn't going ta work
Re-calculating...re-calculating :popcorn:
If I shorten the "fancy front bend" up a bit, I could probably get both fenders out of that piece
...sometimes, with a few adjustments, you can make, what ya got ta work with...work :cheers2:
More "fine tuning" adjustments
* Using a "straight edge" as a guide
...helps ta make "straighter" cuts
I think got my "moneys worth" outta that cut-off wheel :2guns:
After cuttin', I "doubled up" them fender blanks
...& bolted 'em together, using the bolting flanges ;)
Rough cut
The advantage of this concept is
...if all goes well ya get (2) identical pieces :)
...but, the (possible) dis-advantage is
...if ya mess up, they still match :ack2:
Fine(er) cut
Take 'em apart
...& flip (1) over
...& now there are (2) :thumbsup:
These are the only scraps, that we have left out of that whole 13" x 72" piece :2guns:
More measurin' & markin' (where ta put the bends)
...& markin' the bend orientation (upwards or downwards) :thumbsup:
Bolted the bender to the workbench
...& started a bendin' :popcorn:
I installed the "outer" side bends first
Because of the awkward size & shape, I couldn't do much more in/with the bender
...so, I had ta get a bit more creative ;)
Had ta form this bend (for the bolting flanges) using hand tools
A rubber Mallet for shapin' & bendin'
...a steel hammer for "crisping up the bends"
...& a pair of sheet metal shaping plyers
SAM_9335.JPGMore creative clampin'
...& some hand bendin' :cornut:
Flipped 'er over
...& then, bent 'er again :cheers2:
I dry fit, the freshly formed & roughly bent, left front fender :thumbsup:
* Yup, that's a grease gun under the mini-Jeep :popcorn: I gotsta grease my truck, some-a-time, today :innocent::devil2:
Floorboard to body junction (He...he...I see you down there Ducky) ;)
Fender to body junction (I'd say that's a pretty tight fit) :sifone:
I got an E-mail over the weekend about the Jeep Fest
Wholy Crap! we'sa runnin' outta time :ack2:
We gotsta be there, ta get our spot in the parade, Sat morning Aug. 5, 2023 by 9:30am :thumbsup:
SAM_9375.JPGDucky says "we got this"? :cheers2:
Back to the seat backs
I got the hand sewing done, on the seat backs
...but, I didn't like how the back side looked
...& they would be quite exposed :ack2:
So, I added some of the cargo area floor mat material (outta the Caravan that I got the upholstery from) :cheers2:
Left one is just wrapped & stapled
...& the one on the right has the mat, on it, for a "cleaner look" :thumbsup:
Close up view ;)
