'wittle 'wesistor (Mini Jeep)
Hey,
Those wheel well flares, look like they are made outta the seal, for a roll up garage door.
Wow!
...& good eye! ;)
Yup, I made 'em :thumbsup:
But, the material was way too wide (& wonky)
They even stuck out ~1/2" further than the tire
So, I trimmed 'em up a bit
Narrowed 'em down from ~2 1/2" to ~1 5/8"
I think that looks more better :cheers2:
Workin' on/with some of the edge trim that I got out of an Isuzu truck
...but, this transition needed some "work"
But, I also, didn't want to mess 'er up at this "late hour" (~1 week till the parade)
...so, I figured I'd try a "test piece" first (used the rear curve "test piece")
...& cut/shape 'er ta match the body side
Trimmed up & smoothed
...& with the edge trim
Another view
...& another
G.W
Nyssa Oregon
I ordered some trim like that to seal yhe gas tank against the body of my ct90. It has an earlier model gas tank on it, and it doesn't seat properly, a bit of that trim took up the gap and looks good.
G.W
Nyssa Oregon
Thanks fellas, :cheers2:
...Ok, Ima proceedin' :thumbsup:
Here is the last piece, of the steel that I made the grille(s) outta
...& Ducky too ;)
I cut a piece outta it
...did some markin'
...& drilled some small holes
...& then, drilled some bigger holes
Then, "punched 'er out, with a circular piece of wood
...& a nut, bolt & washer
...& some clamps
...& an impact gun
Did 'er (2) times (in a row even)
...& did some creative shapin' before bendin'
* Yea, I noticed the "wavyness" hopefully the bends will straighten them out :idea2:
Put 'er in the bender
A couple of bends later
Then, aligned 'er
...& bolter 'er inta the Brush Guard (ta add some off roadin/explorin' lights)
Whadda ya'alls think?
Another view :2guns:
Put some lights in it!
Yup, that's the plan :thumbsup:
Ima be using the same lights, as I used for the headlights :cheers2:
* Remember, the mini-Jeep is powered by a 48V battery pack
...& "if" using 12V lights
...wesa be needin' (4) of them (wired in series) ta work with its 48V system
** Same with the running lights
...& also, the brake lights (wesa be needin' (4) of them, wired in series) ;)
I got that stupid "bow" outta the front of the hood :wai:
Before :mad2:
After :thumbsup:
How did Isa do it, you ask? :popcorn:
Well, I did some markin' (1/4" across the front edge)
...& some trimmin' (wanted a ~1/4" left in the middle to be able to add a lip, to the front edge)
Then, put 'er in the bender (clamped to just that 1/4" strip)
...& bended 'er (used them wide jaw plyers, ta sharpen the bend a bit more) ;)
Remember when, Ducky said "we B blingin'? o_O
Well, now Ducky says, we B wrappin' :p
This is the stuff Ducky that ordered the other day, after Denny pizzed her off :eek:
Holographic Carbon Fiber Red Laser Chrome Car Vinyl Wrap Sheet Decal Sticker
https://www.ebay.com/itm/162785959644?var=461824542388
Holographic Carbon Fiber Black Laser Chrome Vinyl Wrap Sheet Film Decal Sticker
https://www.ebay.com/itm/132229740194?var=431559477831
Looks interesting
...so, (WTF) I went ahead & started installin' it on the mini-Jeep :thumbsup:
After some trimmin'
...& a "dry fit"
Then, some cleanin'
...& degreasin'
After some stickin' & smoothin' & trimmin'
...itsa lookin' kinda like this :2guns:
