'wittle 'wesistor (Mini Jeep)
At first, I hated it. But once I saw it on there, I'm a fan! Nice work!
Thank you sir(s) :cheers2:
Here is how it looks with the edge trim :thumbsup:
...but, the material wasa a bit short (12" x 60")
So, I used the scrap pieces, from the doorway cut outs, ta extend the fronts ;)
A straight edge helps ta make nice straight cuts
...& Jualla :sifone:
So how did it go? Did the heater keep you warm and the a/c cool? Did it burst into flames? Did you burst into flames?
Just Ducky :p
I didn't know about it :huh:
...but, I guess folks go around placing Rubber Ducks on the Jeeps that they like :thumbsup:
Here we are in the staging area
...& folks just started walking up & putting Ducks on the hood ;)
I walked around looking at some of the other Jeeps
...& stuff :innocent:
When I came back
A little bit later (still in the staging area)
Put them on the passenger seat (for the ride thru the parade) :cheers2:
Ridin' thru the parade :auto:
Cool! The sights look a might young though. What kinds of comments did you get? Did you make it through? Did it snow? Is the cat pi$$ed? Did it try to eat the ducks?
Hey Denny,
Yup, it's a family event
...everyone seemed to like it
...yup, made it thru but, I didn't have much of any brakes (the pedal went to the floor, on the way to the staging area)
...nope, no snow, it was a beautiful sunny day & the temp was ~80*
,,,no, Ducky is always...Ducky ;)
...nope, just sniffed 'em
Um...a hamburger Ducky WTF???
Wadda ya mean, ya had no brakes :huh:
...please elaborate :popcorn:
Well, I wasa drivin' down to the staging area & everything seemed fine
...but, probably the 4th or 5th time that I applied the brakes, the pedal just went straight to the floor (or fender) :smiley_omg:
So, I plopped my foot down onto the ground
...& just applied the 'ol Flintstone type of brakes :thumbsup:
It seemed ta work OK so, "on with the show" :cheers2:
When I got parked in the staging area & had a break from folks looking at it
...I crawled under & took a look
I figured the set screw holding the brake cable onto the brake band "let go"
...but, actually found that the brake drum had moved/slid over a bit
I guess someone :innocent: forgot ta tighten the set screw, that locks it, in place
Of course I didn't bring a set of Allen wrenches with me
...so, I improvised & used a zip tie (came with the flags that they gave out to the participants) ta help hold 'er in place
Like this
...but, I wasa still kinda paranoid about 'em goin' out again
...so, I figured it was best that I didn't try & hold the camera & record, while running in the parade (which SUCKED)
After the parade & as everything was winding down I went ahead & took the 'wittle 'wesistor for a ride around the downtown area
...& recorded a bit of video
Started 'er off with a short build compilation slide show
...& then, on to the ride ;)
G.W
Nyssa Oregon
Like this
I used hose class like that before. It was actually just for the key. The set screw kept coming loose so I used a hose clamp to hold the key
Um...or fender?
...what does that even mean? :unsure:
Well, I designed & installed dual brake pedals.
Here is the lay-out :thumbsup:
The front/Aluminum pedal is in the standard location (right next to the throttle pedal)
...& the intermediate/black one protrudes, outside of the body
* In nice weather, many Jeep owners ride with their left foot outside of the vehicle, on the running board
...& others have installed a peg, to rest their foot on
So, instead of just a "peg"
...I made 'er into a brake pedal
This way I could ride "Jeep style" & still have access to the brakes
Here is another view :cheers2:
So, when the brake drum moved over
...& the pedal went to the floor
...the intermediate pedal went to the fender :ack2:
