'wittle 'wesistor (Mini Jeep)
The back looks really great! The front looks a bit crooked, could be the camera angle. This project shows you don't need a fancy garage to make incredible stuff.
Yup, everything "is" still a bit off
Ima still buttonin' & squarin' "stuff up" :thumbsup:
Across the mid section (~31 1/2")
Across the back (~31 1/2")
Squared up the side panels, with the back panel
...& bolted 'em together
* Notice these
bolt holes will "bolt" (3) different panels together ;)
This ‘splains it better than l can….
Thanks for the info :cheers2:
Yup, I've seen that on Snow Plow Blades :thumbsup:
My Industrial Arts teacher (back in the '80's) referred to it a "Breaking" or Break Bending
Cowl re-work
I took the Cowl back off (to "fix" the bottom bending flange)
This is (1) ofthe offending edges
So, I straightened 'em back out (almost flat)
Then, drew the "new" bending lines (the left side needed ta be bent just a bit "over" 7/8")
Put 'er in the bender
...& bended 'er (hopefully correctly this time) ;)
Re-bent :cheers2:
Came out lookin' like this :thumbsup:
* Notice my supervisor (Ducky) has her azz all up in my business (as usual) o_O
CAD drawings :unsure: Computer Cardboard Aided Design :alien:
Yes sir, I made (several) whole mini-Jeep bodies out of cardboard
...& then, used the "best" ones for templates, to make this body :cheers2:
Speakin' of templates, I used the rear wheel well CAD templates ta make some rear wheel wells outta steel ;)
I had ta make some adjustments, like this edge needed ~1/4" extra
...& the curve in the rear needed "matchin up" (~1/2" off)
Modified CAD template
Gettin' 'er transferred to the steel
I cut (2) "blanks" & bolted 'em together
...so, I could make/create (2) pieces (left & right) at the same time :thumbsup:
...& there were (2) (the exact same but, exact opposites)
Doin' some more bendin' :p
Thats purdy cool. Where did you find the calibrated wrenches? Are those caliwrenches?
Nope, not Caliwrenches
...they are Pittsburg-wrenches
...AKA Harbor Freight specials :cheers2:
They work great for illustrating "gaps"
...& will also turn a nut &/or bolt too ;)
I recently saw a guy who had an ignition switch mounting wrench (used to mount the ignition switch on his mini-bike) :thumbsup:
...& those are very rare o_O
Tailgate
Step 1. Measure & mark
Step 2. Cut
Step 3. Clean/smooth, round & deburr
Here's my state of the art material prop ;)
On longer cuts (over ~6") it helps ta use a straight edge as a guide
After measurin', markin', cuttin' cleanin & smoothin', I put 'er in the bender & bent 'er
Moved 'er up a bit & bent 'er again
After the third bend it looked lika this
This double lip should help make the body more ridged & be safer to the touch
...& this is what itsa looksa like, installed :2guns:
Hey what's all of them holes, in the back, for?
Well, Ima glad you asked :thumbsup:
Those are for the Air Brakes :sneaky:
When driving air flows thru them holes
...& when you apply the brakes, a flap raises up
...& blocks them holes
...which help ta slow ya down ;)
JK...JK :ROFLMAO::ROFLMAO:
...they are for mounting the tail lights
There are gonna be (3) individual 12V lights, on each side, making up the tail lights (I'll explain why later) :cheers2:
...so, I used some maskin' tape ta help align them
Then, used a straight edge ta help square 'em up on the body
Um...that seems a bit too high
...after readjustment (yea, that looks better) :sifone:
Here is what theysa gonna look like
Another view
The center lights (on each side) will be the marker lights (on when the headlights are on)
...& the outer lights are the brake lights
The (4) outer lights will only light up when the brakes are applied
...& being twice as many, they should illuminate brighter than the marker lights, when lit :2guns:
Another view
Started workin' on the Hood
I don't seem ta have a CAD hood template (I did) :mad2:
...so, Ima gonna have ta make another one
Ima also, running low on CAD "fluid" (cardboard)
...so, Ima gonna have ta re-purpose one of the CAD floorboard templates :cheers2:
Here is the "rough" CAD hood template
Dry fitin' 'er on the body
Got 'er nice-n-centered
Worked on the "wrap around"
...& marked where the bending flange(s) needed ta be
Also, marked the front "overhang" (left ~1/2")
...& now, we have a CAD hood template :thumbsup:
But, then I was thinkin' that maybe I should add a rear "lip" to the hood (ta make 'er stronger & more ridged, back in the hinge area) :unsure:
...so, Ima thinkin' that Ima gonna add ~2" to the rear edge of the hood ;)
Now, I gotta get some more 18g. steel ('cuz I don't have a piece ~31" x ~21" 18g. left) :huh:
