'wittle 'wesistor (Mini Jeep)
Or you could just spot weld them together.
Well, now ya tell me :huh:
...(100) 1/4" x 3/4" bolts later :mad2:
Also, I think were far enough along
...so, I went ahead & officially entered 'er into the Jeep Fest Parade
Details, details
...I thought it was FREE
...but, I guess NOT :furious2:
* It does come with a FREE 2023 Jeep Fest participant T-shirt :roflol:
Weatherman said rain is coming :huh:
Um...I gots lotsa bare metal :ack2:
So, I did a bunch of grindin' (entrance/exit openings & wheel wells)
* Here is some notchin' ta remove excess material "up close" ta the line :cheers2:
Notchin' & smoothin'
Then, cleaned 'em up
...& got 'em sealed up/put 'em in primer ;)
Yup, of course I sealed up the inside too :thumbsup:
The fuel fill on the old military style Jeeps is on the drivers side
...between the "doorway" & the wheel well
...& is recessed (for protection) :thumbsup:
So, I rounded up a recessed toggle switch (ta mount our "fuel fill'er" into) :cool:
...& positioned it in about the same place ;)
* Notice, I positioned the mounting screw holes, for the housing, in between the (2) lines?
...these lines indicate where the floorboard bolting flange, intersects with the side panel
...so, those (2) screws will also, help to secure the side panel to the floorboard :cheers2:
Hole sawed 'er
* Yup, I had ta move 'er just a bit because of there being a cross-bar right behind there :huh:
Recessed Charge Port Housing (mounted) :banana:
A better view :)
G.W
Nyssa Oregon
Hole sawed 'er
A better view :)
The fuel tank is actually underneath the drivers seat btw. If.ta want pictures let me know so you aren't guessing
Here's our 1950's era mini-Jeep recessed, charge port (part # MJ-6152023) :thumbsup:
...with connecting plug ;)
JK :p
I used a step-drill bit ta drill 'er out (had a 1/2" hole but, CP needed a 7/8" hole)
...& then, simply mounted the charge port up in there :cool:
Electric mini-Jeep charge port/fuel filler, reporting for duty :cheers2:
