'wittle 'wesistor (Mini Jeep)
Still workin' on the body panels :)
Another view
Still gotta do some adjustments (where the side panel & Cowl intersect)
Here is where the wiring harness comes up thru the body
Yup, got some cargo, in the cargo area already ;)
I found a couple of (little) mess-ups
I cut the wheel well out a bit too big (on both sides, of course) :ack2:
Um... :idea2: many Jeeps have added rubber wheel well "flares" :unsure:
...yea, that's the plan :p
This workmanship is way beyond my hack style!
Well, thats kinda why I jabber so much
...& post so many pics
Just atryin' ta describe, explain & show how stuff "can be" done ;)
...& the outcome or the end product :2guns:
My hope is that others pick up some ideas, concepts &/or tricks, to use in & on their own creations & projects :thumbsup:
...& IMO it seems that you do kinda the same (in your own way &/or style) :cheers2:
* My left brain has been secretly workin' on Morgana (looks around-nervously) that's all I can say for now) :sneaky:
...but, maybe you can/will have a bit more input, on that build :cornut:
You and Hack have definitely inspired me, and I've learned some stuff. Y'all have lotsa to say and it's quite useful.
I really couldn't tell if you wanted to make a Morgan :roflol:
Oh that'll be fun!
For me, I'm just hopeful that my junk will inspire some of the young'ns to put down the video game and got out to the garage and figure out how to actually make something. It doesn't take a lot of money, just some creativity.
G.W
Nyssa Oregon
Another view
Honestly that doesn't look like a large gap. The gap on my jeep is quite large and it doesn't look bad.
P.S if ya want some pics of those flares let me know.
Gap?
If ya talkin' about the side panel & Cowl intersection
...the bottom bend on the Cowl should have been ~1/2" higher (bent at the line) :thumbsup:
The Cowl & side body panel are supposed to come together, nice-n-even, to create a hidden bolting flange ;)
...but, as you can see, the Cowl is ~1/2" too low :oops:
...that'sa why the side panels are kinda leanin' outwards, toward their tops :(
Yes, pics of Jeep wheel well flares would be helpful & appreciated :thumbsup:
G.W
Nyssa Oregon
Gap?
I was talking about the gap between the wheel and the fender.
Curvin' the rear end of the panels is up next :popcorn:
...but, I am kinda leary (not 100% sure) about it (don't wanna mess 'em up now)
So, Ima gonna do a "test bend" (or 2) first on a piece of scrap ;)
This is (1) of the "doorway" cut-outs
...& has the same 1 1/2" flange as the body panels (it should it came off of (1) of them)
I measured & marked the side panel, about where I figured the bend should be
...& I figured (4) "relief" cuts ~1/2" apart, should help 'er bend
Tools for the job :cheers2:
Bendin' aid (I first tried just (2) "relief" cuts but, ended up needed all (4) :thumbsup:
Yup, that seems pretty close :2guns:
I took the "test piece" over to the kart
...& used it to line up where the bends needed ta be (on the panel)
...but, it looks like where it actually needs ta be (dark line) is "off" a little bit from where I thought it shoulda needed ta be (long thin line)
So, I dida some adjustin'
...& went "off of" the new mark
Cut the (4) upper & (4) lower slots
...& got ta rollin' (found that I had ta bend the tabs out of the way)
Rolled :sifone:
Thats some purdy nice sheet metal work. I worked a short time at a sheet metal shop doing QC. Those guys got nothing on you. l haven’t seen a pic, but you must have a brake and a shear?
Thanks again! :cheers2:
No shear
...but, I gotsa Harbor Freight sheet metal bender with ~30" width capacity :thumbsup:
For the side body panels I "picked my battle" by having the place I get my steel from, do some of the shearing
...& also, the long (upper & lower) bends on the side panels
As per this shearing diagram
...& this bending diagram
FYI: most of my "art" work is done in the "great outdoors" on a workbench (solid door)
...under a carport type structure
* I know, Ima still workin' on cleanin' up
...its a "work in progress" :sifone:
G.W
Nyssa Oregon
No shear
My shop is always "a work in progress." It is always a bit messy because of the small space and lack of workbench space.
I gots the rear "curves" done on both side body panels :thumbsup:
...& they seems ta be pretty close ;)
Well, lets see "if" or how well, they fits on the Jeep :)
Another view
Dry fit the floorboards (just ta make sure everything fits together) :cornut:
Front
Rear
ever heard of or done “bump bending”?
Um...nope
...please elaborate :cheers2:
When assembling these steel panels, I have found this bolt hole "alignment" tool ta be very helpful ;)
Sometimes the bolt holes in (2) different panels just don't quite line up (but, they did a little bit ago) :huh::mad2:
Well, just insert this "handy-dandy-little-tool into the offending junction :devil2::innocent:
...& (wait for it) :popcorn:
Ok, now ya can look, the holes have been aligned o_O (no levers or buttons or nuthin') :2guns:
