You have the instrumentation to know whats happening. Whats the expected run time? Obviously you engineered enough capacity into the system to complete the event, but can you drive it home?
Hey T,
Yup, so, we gots us some data to analyze
The battery pack we are currently testing, consists of (4) 12V 20AH SLA's (Sealed Lead Acid)
...& each of these batteries has a usable voltage range of ~10.5V - ~13.3V
When we wire them (4) together, in series, it creates a 48V 20AH battery pack
...with a usable voltage range of ~42V - ~53.2V
These 20AH batteries should be able to "put out" ~20A for 1 hour
...&/or ~40A for 1/2 hour etc.
So, now we have a 48V battery pack, with a usable voltage range of ~42V - ~ 52V
...with a 20AH (nominal) current rate
...but, "if" we drain it more slowly, like let's say ~10A
...it should be able to maintain that "out put" for ~2 hours
Now, analyzing the data in the last video:
Voltage
When we started, the voltage level, of the battery pack, was 51.46V
...& then, with the voltage drop, upon hard acceleration, the voltage dropped down to 47.72V (~3.75V drop)
When we ended, the test run, the voltage level was 50.8V
...& the voltage drop (just before the end of the test) while "under load" was ~46V (~4.75V drop)
Current
Watching the video, the highest Wattage I saw was ~1,223W
...with a corresponding Amperage draw of 26.3A (@~5:39)
While cruising at top speed (~22MPH) with a WOT (wide open throttle)
...the Wattage was usually ~500W - ~700W
...with corresponding Amp draws of ~10A - 15A
So, to put everything into perspective, this test lasted for ~20 minutes
...& the kart traveled ~4 miles
...but, only drained a couple of Volts out of the pack
So theoretically, "if" we can maintain a 10A - 15A rate, for most of the time, during a 1 hour race
...we should have enough "in the tank" (of this little battery pack) to finish the race
...& would have traveled ~12 miles
...with a top speed of ~22MPH
* There is so much info, I hope this make sense & there's more to come
