I like it. You could also put some "relief" in the mounting holes to allow for some minor adjustment. Not that your calculations aren't spot on.
Hey ez,I like it. You could also put some "relief" in the mounting holes to allow for some minor adjustment. Not that your calculations aren't spot on.
Hey BBR,Ready for completion! We'll need a video of you crushing the competition!
Hey Denny,Lawn chair webbing would have been lighter for the seat belt.
Nope!So the support did not solve the "wonky" issue?
Be sure to check that the bearings are tight in the hub as well, there were some fitment issues as I recall.hem plastic wheels are doin' a lot of flexin'
Hey T,Be sure to check that the bearings are tight in the hub as well, there were some fitment issues as I recall.
Hey Denny,I know you are not going to agree with me but here goes. You are running the tie rods in compression and they are solid. I see them flexing. If you ran them in tension being they are solid they would not flex. But that would be a lot to re-engineer. Instead I would get some tubing and cut the ends off and weld them into the tubing. Tubing is more resistant to flex than the solid rod. Just my 2 cents.
dat true. Double check everything twice then one more time. I’m no help on issues involving steering.Hey T,
Yup, they all seem good-n-tight (& "glued" in well)
*Thinkin' out loud
I would think that if there was much wigglin' goin' on in that area
...the rotors would be makin' some kinda noise while, rattlin' around in the calipers
...& maybe even gettin' warped or bent up
