jamyers
In the below pic, I'm wondering if tab "1" contacts "2" when you close the throttle all the way, which should kill the engine. If so, you could bend or cut off "1", then hook your remote kill switch to "2" easily (after reconnecting those wires above)
If you haven't already, you'll want to loosen wingnut "3" just enough for the throttle to move freely up & down.
"4" and "5" are your dual governor springs, mine only has "5". I believe "4" is for a governed idle speed. I'll post and scan how to adjust the governor in a little while, along with the table on which "5" hole gives you which "Top No Load Speed".
"6" is the governor shaft, you'll need to loosen that nut/bolt to do the static governor adjustment (rarely out of whack but worth checking.
