Yes, lapp the flywheel.Does it come with a stock carb? If so I have this that I bought awhile back that i can use for throttle linkage how does it come with everything but a flywheel? LolView attachment 142451View attachment 142452
It hurts my eyes lol maybe +10hp at least, I will deffinetly order some magnetic drain plugs, ill just run that stock carb for breakin then monday when I swap everything over Ill change out the carb tooI'm conflicted.
Did the Predator MAX PERFORMANCE gas tank add 50hp or take away 50hp ????![]()
She's back running, new tank, carb, gaskets, fuel line, airfilter and oil change.
Get you some extra gaskets.It hurts my eyes lol maybe +10hp at least, I will deffinetly order some magnetic drain plugs, ill just run that stock carb for breakin then monday when I swap everything over Ill change out the carb too
I got lots of gaskets ill have to measure them when I get home because they are all different thicknesses, at that compression ratio would 93 octane be good or do I need to run higher?Get you some extra gaskets.
Jerry is the only 1 I know of that has the .012" thick x 70mm head gaskets.
If this Ducar is like the pred, then it's gonna need .024" thick gasket to get that .030" piston to head clearance. And that should make it around 9.1:1CR with the stock rod and dished piston.
Of coarse, I'm jus assuming, won't know til I get it apart.
You will be fine with 87 octane at 9:1.I got lots of gaskets ill have to measure them when I get home because they are all different thicknesses, at that compression ratio would 93 octane be good or do I need to run higher?
Feelers gauges or calipers will work, that's what I use.Hah your old lady is gonna beat your a$$ lol idk about flat, also how would one go about measuring those clearances? I have a set of feeler gauges and calipers and thats about it lol
Niceeeee hopefully mine comes in today thats a clean lookin little motor I can wait to see if the one I ordered from arc will be any different. More money= more parts= mo powaaa. I might order one of those coils too not too expensiveSurprise, surprise, Surprise๐ซข
View attachment 142459View attachment 142460View attachment 142461
It should be the exact same from ARC.Niceeeee hopefully mine comes in today thats a clean lookin little motor I can wait to see if the one I ordered from arc will be any different. More money= more parts= mo powaaa. I might order one of those coils too not too expensive
I have lots extra lolView attachment 142466
