USAMAC
Hello all,
I have a Dingo Manco Fox 2x5 LXT that I bought off of someone from FB Market about 2 years ago. At the time, I was in full blown house building mode, so when we began having issues (almost right away) I procrastinated. Our issues began when the not in terrible condition drive belt broke off. I had planned to order one forever but let it slide until my son asked me again about it recently so I got motivated. I ordered what I thought would fit, based on the necessary measurements and swapped it out. This did the trick, but after taking it out to ride for a couple hours I found that the clutch pulley was producing so much heat it melted the zip tape I used to mend the converter cover. The kart kept stalling out about every 5 minutes. I also found that this kart keeps trying to go with the foot off the break and I cannot hold it back. I can't seem to find anywhere if that is normal because of the torque converter or if it should stay still in idle?
With the problems I was having, I decided to order a new kit from amazon. The guy I bought this from had replaced the motor it came with originally, with a Predator 212cc 6.5hp Gas. The Drive shaft for the converter pulley that he put on there was exceptionally long, it actually went as far as the motor is wide. He had fabricated a mount out of steel that he put a small steel tube on to hold this long shaft with appropriate bearings etc.
I pulled the old converter kit off, disconnected the chain and throttle cable and pulled the motor out to change the oil and to turn the crank to make it easier on my kids and remove the operation of the oil sensor. Eventually, I want to remove the oil sensor, governor and do a stage one, but I don't want to bother until I can get the kart running properly with this new converter kit. I ended up using a grinder to remove the pipe the previous owner had added to the mounting bracket he fabricated for the old converter shaft.
I have some pics to attach with where I am at now, but I'm kicking myself for not taking any before picks of how it was assembled. The issue I am having, is I believe that the drive sprocket is way too high and too close to the motor, or the motor is too close to it, I am unsure and this is definitely where my inexperience is hindering me. I keep watching videos and looking at pics online, but I can't quite get enough detail to determine where the problem lies in this kart's setup.
Should I move the main sprocket or should I move the motor? I am also thinking I need to elevate the motor even more than he did with the bracket he fabricated. I'll have to use wood or hire it out, because I do not own or have much experience with welding. Is there something I am missing? Let me know if more pics are needed, I will get them when I get home.
I was able to source 2 different #'s for this kart, but I don't know which is mine or if relevant to the discussion here. Maybe one is a 1 seater and the other is 2 seater? Or possibly the years they were made?
485B-19 FOX 2X5 LXT
485B-09 FOX 2X5 LXT
485B-19 FOX 2X5 LXT
485B-09 FOX 2X5 LXT
