Diamonite Electrathon America Racer
Up next was installing the front & rear wheel sub-assemblies
The Tie Rod "hole" lines up nicely, with the Pitman Arm :thumbsup:
But, durin' steering "turning tests" I found that the Tie Rods "hit" the edge of the access holes :confused:
...&/so, had ta do some modifyin'
The hole needed ta be "moved" upwards & backwards...just a bit
...so, I used a "temporary pilot hole" ta "get 'er done ;)
Only removed "this much"
...& a nice-n-clean cut :)
Yes! That's mucho bettero :wai:
Yup, the other side "clears" nicely, in both directions, too :cheers2:
Up next was ta get the Roll Bars installed
I "lined" the holes on the monocoque ta "pad" 'em a bit, as the bars "slide in" ;)
Well...huh? I didn't take any pics of 'em installed :huh:
...I'll do better...next time :thumbsup:
The EA rules require a 4" red triangle under/around the Main Power Cut-Off switch
...so, I got some Permanent Red Vinyl
...& drew up a 4" x 4" x 4" triangle
Then, made up a template (outta some packaging plastic)
Checked (test fit) how it would look on the dashboard
Then, me & Ducky went ta workin' with the Vinyl
We gots us a 4" x 4" x 4" red triangle
...with nice-n-curved corners :sifone:
Even though it is brand new paint
...I still gave 'er a wipin' off (just some Alcohol)
...ta make sure the sticker "sticks" goodly
Installed & workin' on the "cut-out" for the Circuit Breaker
Punched a couple a holes
Ju-alla
In this pic, they show what, at first, I thought was a Shunt
...but, it's "in" the Positive (+) side of the circuit? :huh:
That can't be right
...because a Shunt "goes in" the Negative (-) side of the circuit :unsure:
What they are showing is a Cut-Off switch (Isolation Switch) & a Fuse
Like these
I'm using this Circuit Breaker, as both components (an Isolation Switch & a "re-settable" Fuse)
The rules even specifically approve of, using a CB for this purpose
The rules also specify that this Isolation Switch must be easily accessible by the driver (without having to reach outside of the cockpit)
...& by race officials (without having to reach inside, of the cockpit)
* Yup, I think we have this "covered" :thumbsup:
Yup, we are using "wire protection" ;)
Nope, we are NOT using the vehicle frame, as a conductor
...as/for a Ground/Negative (-)
I got my notes out, ta wire-up the PZEM-051 (AKA Power Meter) correctly
Yup, White, Green, Black & then Red
PZEM-051 installed
On/Off switch (AKA Power Lock) installed
A view of the dashboard from the cockpit
Up next, Hand Controls
9 Brakes and Axles (page 8.)
The rules require brakes, on at least (2) wheels (yup/check)
We have a Brake handle/lever, on the steering wheel
...& Rotors & Calipers, on the (2) front wheels (yup/check)
Now, we need brake cables, to connect 'em together
...& make 'em actua-table, by the driver
But/also, I "ran" into a couple of "issues" :ack2:
1.) How do we connect (2) separate Calipers to (1) Brake lever? :unsure:
2.) I seem to have made the brackets so that the Calipers mount, upside down :furious2:
Well...for #1, I found a single pull, dual cable, brake cable (seem ta be for Adult Tricycles) (~$18.00) on Amazon
(1) "leg" of this cable looks ta be ~4' (48") with a ~5' (60") inner cable
...& the other "leg" looks ta be ~5' (60") with a ~6' (72") inner cable
As for #2, I'ma thinkin' I can just connect the cable(s) to the Calipers "backwards" :geek:
By "switching" around the cable housing mounting "eye" (or bracket)
...&/with the inner cable "clamping" mechanism/bolt
I can then, "run" the cable(s) to the Caliper properly (from the top side)
Like this :thumbsup:
My .02.
Is the sheath gonna be strong enough to handle the work load of working the caliper?
Seems trivial, but your changing the workload distribution from pulling the steel cable to pushing the wrapped sheath.
My .02.
Hey WTR,
IDK?
I thought this was a seldom used but "standard practice" cable actuation method.
Over the years I've seen bicycle brake systems, where both sides (cable & sheath) "moved" during brake actuation
I guess "we" will see how long it lasts...together :cheers2:
Can’t you just flip the calipers over and swap them side to side?
Hey Denny,
Well...shucks...why didn't I think of that?? :smartass:
Um...nope...it's not that easy :confused:
This is how the Caliper is supposed ta be positioned on the Rotor
* Notice how the pads fully cover the Rotor?
I have a set (L & R) of these Black Calipers (about same as the red ones) ta show ya
* Notice how the pads area is "clocked" differently?
This is how the Caliper is positioned when "flipped"
* Notice how the pads don't hardly even touch the Rotor?
Finally got a pic of the Roll Bars
Got the wiring harness (re-installed)
* Notice when the seat is "in place" it completely "covers" the wiring harness :thumbsup:
Wiring harness mounting strap/strain relief (inside the cockpit)
Wiring harness mounting strap/strain relief (outside the cockpit)
* The same nut & bolt, secures both of these wiring harness mounts, to the cockpit ;)
To adjust front tire alignment
...I first squared up the racer, with the workbench
Then, squared up the steering wheel (nice-n-straight) with the floorboard
Seems ta be ~11 & 9/16"
Yup, on this side too
Next, I squared up the wheels with the workbench (& by extension the racer)
Seems ta be ~7/8" on the "back side" of the wheel
...& ~7/8" in the front too
Then, adjusted the front edge of the front tire's inwards ~1/8" (Toed In would be the technical term) :geek:
* Tie Rod adjustment is accomplished by turning the tie Rod End (inwards or outwards) on the threads of the Tie Rod
Like this
* Notice the front edge of the tire is now a bit over 1"
...where as it was ~7/8" :cheers2:
After alignment, just "synch" the "jam-nuts" to "lock" the settings "in place" :thumbsup:
