Diamonite Electrathon America Racer
The only thing I noticed was the power meter seemed ta be giving "hokey" readings
Why are (do I think) the reading from the Power Meter "hokey"?
Well, let's establish the specs (of the components we are working with)
...& then, maybe expand on the discussion :thumbsup:
So first, I went back to the Sequoia build thread (my digital notebook)
...& found some specs, on this battery pack that I posted, when I first got it ;)
52V 20Ah with 30A/40A BMS Lithium Ebike Battery for 200W~1500W Electric Bicycle Motor
  • Voltage:52V
  • Battery Capacity: 20Ah
  • Energy: 1040Wh
  • Configuration:14Series 8Paralles=112pcs cells
  • Item Length: 260mm
  • Item Width: 70mm
  • Item Height: 160mm
  • Item Weight:≈5.6KGS
  • Standard charge Current: 2.5A
  • Maximum continuous charge current: 5A
  • Max Continuous Discharge Current: 30A/40A
  • Peak Discharge Current:90A/120A
  • Charger Input:AC 100-240V
  • Charge Cut-off Voltage:58.8V
  • Discharge Cut-off Voltage: 39.2V
  • Charger: 58.8V 2.5V
  • Speed Controller specs:
    • Model: YK-31
    • Power 1,000W: for use with a 1,000W brushed motor
    • Output Voltage DC48V: for use with 48V Direct Current systems
    • Current 28A: can output up to ~28A
    • Short Voltage 42V: controller has low voltage protection circuit
    • * Which means, the controller will "shut down" when the voltage in the battery pack drops below the preset limit of ~42V
    • Throttle Voltage1-4V: the controller is compatible with throttles that have a 1V-4V rangeSAM_9116 (1).JPG
    Motor specs:
  • Model: MY-1020
  • Voltage: 48VDC
  • Rated Current: 26.7A
  • Rated Output: 1,000W
  • Rated Speed: 3,000RPM'sSAM_7682.JPG
Um...just got a "call" BRB :cheers2:
l like the "evil" theme but not evil knievil.
maybe "evil artist" no maybe
"evil f'n artist"?
Hey T,
Evil f'n artist sounds kool
...but, the EA program is "geared" towards kids/students
...so, we'll have ta save that, for another project (maybe the Morgan) :cool:
Fine, go poop. :ROFLMAO:
Hey Denny,
Kinda reminded me of: "Hope ya had one hell of a piss...there Arnold" :mad:
I switched out the 50A Shunt, with the 100A Shunt (that came with it)...just to see
Yup, for some reason (should have worked fine) the 50A Shunt wasn't co-operating with the meter (it came with 100A Shunt)
...so, I took 'er apart & did some investigatin' :thumbsup:
Ta do this I had ta remove
1.) the battery pack,
2.) the seat
3.) the wire strain relief clamps
4.) the insulator sleeve too
First, I double checked that I had the wiring/connections correct
Yup, everything seems fine ;)
White wire on the P- side of the Shunt (to controller)
...& Green & Black wires on the B- side (to Battery pack)
So/then, "to see" if the Shunt was the issue, I switched/changed 'er out (50A out & 100A in)
* Had ta switch/change some of the terminals too
Back in Business :2guns:
Now, just reverse procedure
...ta "put 'er back together" :cheers2:
OK Let's get back to the "crazy" readings, the power meter was displaying, in the 1st video
The Voltage & Ah readings seemed normal
...but, the Wattage & Amperage readings seemed/were really high
I saw (& verified by watching the video) (another version of a digital notebook) Wattage readings "up" in the 3,500W's
...& Amperage readings "in" the 60A's o_O
But,
Readings like this are basically impossible on this system as:
A.) the motor is only rated 1,000W
B.) the controller is only rated 28A
C.) the battery pack's BMS is only rated for 30A/40A
I could see/understand (1) component being over-burdened
...& "giving 'er all she's got capt'n"
...but, NOT all (3) components
So, a 1,000W motor "registering" as ~3,000W (is/would be x3)
...& a 28A controller "putting out" ~60A (is/would be x2)
...&/or a battery pack, with a 30A/40A BMS "putting out" ~60A (also x2)
Again...IMO...NOT likely
Then, in the little dinky bit of data we got from the 2nd video, I saw readings of
...~559W & ~10.07A
...&/then, ~834W & ~15.42A
...which are both mucho more like it :thumbsup:
In my little knowledge of those meters, (I installed one in my rv.)
Is the brain box calibrated to the shunt?
I get it's reading the voltage drop, but does changing (for example) a 100a to a 50a shunt change the reading the box is looking for?
A=w/v 🤓
A=w/v 🤓
Hey WTR,
I have PZEM-051 meters on several karts, several EA racers & my ElMoto (electric motorcycle) too
...& haven't had any issues :wai:
But, the readings, with the 50A Shunt, were definitely "off"
...& (now) they seem proper/normal, with the 100A Shunt, that the meter came with :thumbsup:
So, yes, it seems like they may be calibrated, to work together :cheers2:
Comparison example:
Polaris EA racer (has heavy pipe frame but, low rolling resistance wheels)
...& this video has some good "footage" of the meter ;)
The speedometer, I'm usin', is just an old cell phone (without service)
...with a speedometer app installed ;)
It displays the
...Current Speed (nice-n-big-n-clear) :2guns:
It also, displays & records the
...Top Speed
...Average Speed
...Distance traveled
...& has a built-in timer (stopwatch)
* It can display the speed data in Analog &/or Digital
...& I think it also shows the route traveled (map) 🤓
I used some industrial Velcro ta mount it to the dashboard (after cleanin' the surface...of course)
Looks like this
...mounted good-n-secure
...but/also, easily removable for re-charging &/or for use on other racers :thumbsup:
Instruments (total cost ~$20.00) :cheers2:
It rained on & off almost the entire weekend
...so, more testin' was put "on hold" :confused:
Sometimes the rain wasa commin' down in "buckets"
* See how much water is "shooting" out that downspout? o_O
In between down pours, I worked on adding a brace to the rear deck (1" x 1" x 16g. square tube, from an old table/legs)
This brace will strengthen the rear deck area
...strengthen where the upper seatbelt shoulder straps mount
...& will "act" as a lifting handle, for/when lifting & moving the rear of the racer too (triple duty) ;)
I got another/fresh camera
...& we finally gots us some dry weather :wai:
So, we (my daughter & I) loaded the Granite racer up
...& took 'er to a local parking lot (business closed/for sale)
We didn't try-n-get any data (speed or power)
...we just "zipped" around, the parking lot, for a bit
Basically, just getting a "feel" for it...for now ;)
So you have a container full with 20 some odd racers, but yer so busy building the next one, do you have time to actually go race them?
I think the next one is partially complete?
Hey T,
Actually, I only have ~10 karts that are "ready to roll" & fully functional...ATM
...6 here & 4 in storage :thumbsup:
But
Some issues have arisen about my storage situation :ack2:
I sold a piece of property ~15 years ago
...& "in" the deal was a "lifetime use" clause, for a small storage lot at the end of the property ($5.00 per year)
But,
The guy I sold it to, suddenly passed away back in 2018 😥
...& since the family has been fighting & arguing & refusing to settle the estate
...& NOT paying any of the bills (like property taxes)
Now the County is working to foreclose on the property, for back taxes (~$60,000.00 in back taxes)
...which will make my "lifetime use" deal NULL & VOID :huh::furious2::mad2:
So/now, I'ma probably gonna have ta downsize a bit (karts, spare truck parts, extra materials etc.)
...maybe a lot...just "gettin' in to it" :(
* As far as a next one
...of course my "left brain" has been workin' on "the next one"
But
Yea...maybe I should just "ride some of the ones I already got"...for now :auto:
