Am I seeing this correctly? Just for what it's worth, I don't think you'll be achieving speeds where this will matter.
Hey Ez,
The (3) areas of interest or potential goals, that I'ma lookin' for, from these Venturi "tunnels" are:
1.)
Ground Effect/Down Force
To potentially lower the pressure, of the air, under the racer
...so, that the ambient (now) higher-pressure air above the racer, "pushes down" on the racer
...enhancing the tires "grip-ability"
2.)
Principle of Mass Continuity
To potentially create a (under car/thru-vehicle) suction, that actually helps to "pull" the racer thru the air
...instead of "fighting with/against" the air
...&/or tryin' to "slip past" it
3.)
Anti-Drag
To potentially inject some higher-pressure air
...into the "draggy" lower pressure area
...that is known to form, in the wake, behind a racer
Speed & Mass
Speed?
How much speed is required
...to generate any of these effects? (lookin' ta find out)
Effect vs. overall mass of the object?
How much any of these effects
...will affect a mini-racer vs. a full-size race car
* If let's say a full size race car (~2,000 lbs)
...going 200 MPH
...can generate (lets say) 1,000 lbs. of down force
Then,
What kinda DF could be generated by a mini-racer (~200 lbs.)
...going 25 MPH?
...maybe ~100 lbs.?????
Heck,
Even 10 lbs. of DF
...should create a noticeable effect
...on a ~200 lbs. vehicle
If nuthin' else, we gonna find out whether any of this was even worth the effort
