Diamonite Electrathon America Racer
Sorry I was late to the party. Body filler and a long board with 180 grit will straighten it out.
Hey Denny,
It was an experiment
...a learning exercise
...& I wasa just sayin' :cheers2:
F that!
...my arms would "hate me"
...also, just sayin' :thumbsup:
& (& it's a big one)
I wouldn't have the opportunity to "try again"
...& try-n-make something...even kooler!
Let me introduce you to...Plan B :2guns:
Someone in the back says:
"It kinda looks like ya put that "embellishment" thing, on backwards :confused:
I says:
"Um...lemme check :thumbsup:
...yesterday wasa long day" :cornut:
Man you always have me guessing.
Isn't that the down side? Inside? whatever your knees see?
Looks like the tape didnt like the resin.
Hey WTR,
The tape seemed to stick (& stay put) when "stuck" to the cardboard
...but, where the tape wasa overlapped
...is where the "issues" arose
Yup, your correct :thumbsup:
The plan was ta make a FG "cavity" mold,
...off of that CAD "plug"
...so, the inside wasa smooth
Then, make the actual FG hood
...off of the FG "cavity" mold
...so/then, the outside would be the smoother side (like the rest of the monocoque)
I'ma learnin' more & more about what "works" (or how ta work) with this "stuff"
...& what doesn't ;)
I says:
Nope! I double checked...were...good :cheers2:
So, a "cavity" mold...like this...is what I wasa goin' for
...but, smooth inside (important detail)
I had ta tell myself "stop bein' so lazy & do it right"
So, I got me some 1/2 MDF
...after some measurin' markin' & cuttin' (basic hood mold pieces)
...& markin' for the hood embellishment (if we gonna do it...let's try-n-make 'er look kool)
I did some drillin' (1" holes) to establish the corner/curves, of the hood embellishment
Set up a "guide board" ta help the saw (& me) cut a straight line
Makin' sure the "adjustment" of the "guide board" wasa in the right place, for the "foot" of the saw
After cuttin' the "straights"
...I used a jigsaw to cut the shorter "runs" in the front
Jua-lla
Another view
A close-up view of a "corner/curve"
Hood embellishments on real cars, "ramp up" from the surface of the hood to the top surface of the "feature"
...not, a hard "step-down" like this
So, we gots ta add some fillets
Ta make fillets, I've seen many materials used like:
....clay, wax, bondo, plaster, spray foam & I've even used Latex caulk
...but, I'ma just gonna "machine" them :thumbsup:
Weapon of choice, for this procedure, would be a router (with a 45* angled bit)
Yup, seemed ta "do the job" quite...well ;)
Doin' somethin a bit different
...on the back edge, of the "feature"
We'll see how it "turns out" :cheers2:
Next, I added the dash panel to the "hood" mold
...& then, the (2) side panels
* Hi Ducky...I see you! :thumbsup:
...& then, finally got to this "painted up" stage
Sanded & smoothed
Got 'er all ready to coat with the PVA
Coated
This time I'ma just doin' a layer of CSM
...& then, lettin' 'er cure a bit
...before addin' more layers
Ta try-n-make sure I get in, all of these nooks-n-crannies really well :thumbsup:
A couple of hours later
...after the first layer wasa pretty well hardened up
...but, still good-n-tacky
...I added a couple of layers of the 1708 FG cloth
* I made sure to get a "good layer" on the dashboard "panel" ('cause it's the upper steering support)
...& on them "wrap arounds" corners too ('cause they help support the dash "panel") :thumbsup:
The OD of the upper steering support bearing is 1 3/8"
...& I have a 1 3/8" hole saw
...but, sometimes the holes they make are not so accurate
So, I did a "test hole" in a scrap piece of MDF
...yup it seems ta fit pretty nicely
Marked the center of the dash
...& cut out the hole for the upper steering support bearing
Wow! I must say, this is pretty thick
Measures out to ~1/4" thick
Upper steering support bearing installed
Closer up(per) view
To attach/mount the hood my first thought was to bolt & bond
...so, I made up some "bondable fasteners"
Single bolt units for the front
...& (2) bolt units for the rear
* The nuts (& washers) come off before installation
All set up ta get 'em installed
...& then, the hood bonded down
Then, I thought:
"If I'ma bondin' it down
...then, what the "F" are the bolts for
...as it ain't ever gonna be unboltable/removable...ever again"
So, I revised the plan
...& just bonded 'er down
...usin' ~8 oz. of resin
Masked off the inside of the monocoque (ta help keep 'er clean)
I used 1/2 of the resin to "glue" strips of FG cloth around most of, the inside of, the perimeter of, the hood :thumbsup:
Then, simply folded 'em down, on themselves
Gooped 'em up with the rest of the resin
...counted to (3)
...& "flipped" 'er over into place
...& even, "nailed it" on the first shot :2guns:
* I used some gravity clamps (bricks) for the thicker part (dashboard area)
...& some manual "screw clamps" in the front corners
I tried to "match up" this front seam as good as possible
* Theres still a bit of a "gap"
...but, it's well workable :cheers2:
Man!! You do great work!!💪
I hate working with glass fibre though
Hey Landuse,
Good hearin' from you
...haven't in a long while :cornut:
Thank you...my friend :cheers2:
Yup, I agree FG is a very unique material ta work with
...but, the more experience gained
...the easier this stuff is ta work with ;)
I'ma tryin' ta simplify the process, a bit
...for me & you guys too :thumbsup:
