Diamonite Electrathon America Racer
Sorry (not sorry) for all of the "info dumps" :thumbsup:
...but, "if" ya think about it
...most of these "steps" are only 15 - 20 min "jobs" ;)
So/see what a Mo Fo can do &/or get done
..."if" he or she doesn't sit around watchin' TV (for hours)
...or "stuck" to them stupid phones (just scrollin') :mad:
Moral of the story:
Step away from the TV
...&/or put the phone down
...& DO SOMETHING! :cheers2:
A view of the cockpit with the inner "saddles" installed ;)
A view of the rear "saddle" area
...from up underneath
Installing the swing arm
* Notice how the swing arm can "swing down" straight down
...for easy access to the rear wheel, motor & chain?
Looks like this
...when "swung up" in place
...& sittin' on the suspension "pad" :thumbsup:
Whats the 7 layers come out to in thickness?
Hey WTR,
I removed the front "saddle" ta drill out the hole, for the steering shaft, in the FG
* So, I didn't affect (over drill) the size of the holes, for the steering shaft bushing, in the "saddles"
After drillin' I took some measurements...for us :cheers2:
...& the FG, in this 7 layer area, looks ta be ~1/4" thick ;)
The area under most of the bolt holes, look ta be ~1/4" thick too :thumbsup:
Now, I'ma workin' on installin' the steerin' shaft
Also, "set" the seat in place
...ta double check
...some inter-cockpit-al dimensions
With a dashboard/upper steering shaft support
...maybe about something like this :thumbsup:
I'ma gonna try-n-use this Butterfly style steerin' wheel
Looks pretty kool
...& has these "nubs" stickin' up on each side
...that can be used for mounting hand controls (like a Brake lever & Thumb throttle)
Also, includes my unique, custom (should be patented) flip-up steerin' wheel mount
Uses a simple spacer
...& a pressed steel bearing, outta a HF wheel
Should "go" maybe something like this
Ta double check
...& try-n-be a bit more scientifical
...I went to my Hell-raiser kart
...& took some measurements
From the floorboard up to the upper steering shaft support
...looks ta be ~14"-15"
From the center of the steering wheel to the back of the seat
...looks ta be ~23"-24"
A better view
Back at the racer:
...looks ta be ~14"-15" CHECK
From the center of (where) the steering wheel (will be) to the back of the seat
...looks ta be ~23"-24" CHECK
A better view
Now that we know about where the steerin' wheel (& upper support bushing) need ta be
...just need a quick mark
Should look about like this, when installed :thumbsup:
Side view
See how much (more) room there is with the steerin' wheel...flipped up ;)
Another view
Lookie what I found on the side of the road (more free materials) :wai:
* TIP: Whenever ya get something new
...don't just set the carton out to the curb o_O
As then, folks (& thieves) now know:
...A.) you have just got a brand new (fill in the blank)
...B.) Now know all of the details/features & everything about it :oops:
This is some pretty "beefy" cardboard :thumbsup:
* Hi, Ducky :)
I'ma gonna use it for some CAD work
...like for figurin' the dash/upper steerin' support
First thought wasa something like this (but, closer to the bearin')
Then, I got ta thinkin'
...maybe I can incorporate the dashboard, upper steerin' support & the hood
...all into (1) unit
Another clos(er) upp(er) view ;)
Your creativity and repurposing is amazing! Top notch brotha!
Hey Grizz,
Thank you, my friend! :cheers2:
I love it when the craftsmanship gets noticed
...& even more when it gets appreciated :love:
Way back when
...most everything I made, was from repurposed materials
...so/now, it's just part of my MO (method of operation) ;)
Again, thank you
...your comment really "made my day" :sifone:
Been workin' on a mock up of the hood, dash, steering support combo unit
Side view
Side view w/steering wheel "flipped up"
View from the cockpit
View from the cockpit w/steering wheel "flipped up"
The "proper way" or standard procedure ta "turn" a "piece" like this into fiberglass would ta be:
1.) get some MDF (probably 1/2")
2.) measure, mark & cut it up
3.) assemble it (then, wait for the glue to dry)
4.) shape, smooth & sand it
5.) paint it (then, wait for the paint to dry)
6.) coat it with a PVA (Poly Vinyl Alcohol) release agent (then, wait for the PVA to dry)
Then, (7th step & probably a couple of days later) ya can do a "lay up" of a couple of layers of FG
...just ta make the mold :thumbsup:
After the FG cures ya gotta "pop" the FG mold off of the wooden mold
...clean 'er up
...fix any flaws
...coat it with PVA
...& then, do the FG lay up, for the actual part ;)
Experiment:
I got an idea
I'ma just gonna try-n-make a FG mold off of this CAD piece (skippin' the wooden part...completely) :innocent::devil2:
So, I covered the CAD hood with plastic box tape (as a PVA like "barrier")
...while Ducky napped :)
Looks like this...so far :cool:
Also, had some ideas for some kinda hood "embellishment"
But, figured, let's see how this turns out...first...before we B gettin' too fancy :cheers2:
Before fiberglassin'
...it's best ta pre-cut the FG cloth
...for the mold (folded)
I went ahead & pre-cut the FG cloth
...for the actual piece too (on the roll)
* Used my "handy dandy cutter" :thumbsup:
Now, we ready
Gave the piece a good pre-coating of resin
Layed on & aligned the first layer piece of CSM
Then, "rolled" a good coating of resin, on top, to "wet-ten" the cloth
* Just this first layer "took up" 16 oz. of resin :oops:
Then, did a layer of the stronger 1708 cloth
Then, another layer of the 1708
...for a total of (3) layers (same as most of the monocoque) :thumbsup:
* Seems ta be workin' OK...so far :)
Now, we gotta "see" how everything "looks"
...after (if) we get the FG mold off of the CAD form :cheers2:
Why not just coat the cardboard with resin and fiberglass cloth and leave the cardboard in it as a strengthening device. I’ve done that with race car parts and it works good. And ends up being lighter weight and stronger.
Hey Denny,
I kinda think this is "before the fact advice...not after the fact advice" o_O
Next morning
De-moldin' (standard procedure)
Ju-alla
Tremendous Success & Epic Failure...all at the same time :confused:
Technically "it" worked
...& the CAD mold didn't even get destroyed durin' de-moldin' :thumbsup:
But (& it's a BIG one)
The "face" surface is horrible (surface of the moon...like) :furious2:
Closer upp(er) view
* Note to self: Don't do that again :cheers2:
