Diamonite Electrathon America Racer
These things happen
Actually, I had a feelin' as I wasa buildin' the swing arm (man this thing is turning out a bit longer than I thought) :huh:
...& so, wasa kinda expectin it :confused:
Don't worry...my friend, I got weapons of mass destruction :innocent::devil2:
So, I did some measurin' & markin'
Got out some tools & PPG
Drilled some holes to establish nice-n-rounded inner corners
...& used the vacuum ta "suck up" the debris
Post-surgery
Um...kinda tight??
I must say...we gettin' closer :thumbsup:
I Installed the spindles & front wheels
So, I could do a front wheel clearance test
A little "tight"
...but, not too bad :thumbsup:
Looks like it'sa gonna need just a little (dinky) bit of trimmin' ;)
Now, let's get T's hubs mounted
...with the rotors
...& Caliper mountin' bracket
Another view
The Caliper should "go" about here
Ta make some Caliper brackets I got out some 11g. steel & an old Aluminum sign (~1/8" too)
First thought (attempt) was to make the Caliper bracket outta the Aluminum...ta help maintain "lightness"
...so, I used my plastic template ta mark the Aluminum
Close up "side view" of materials
But, after cuttin' 'er out
...I noticed some warpage
Should look like this
That's NOT good :furious2: if it's already warping
Back ta the material "pile" ;)
Whilst lookin' for more materials ta work with
...I noticed:
K - Read
...on the side of a little box??
Hey it's a note from my buddy T
...from (way back) when he sent the hubs, to me :bannana:
He's sooooo Kool! :2guns:
Thanks, T
...your the best! :cheers2:
Whilst I wasa lookin' it started raining
...so, I had ta "weatherize" the monocoque o_O
But, inside my new & improved work area
...wasa still nice-n-dry :wai:
The 11g. steel just seemed too "beefy" & heavy for this situation
So, whilst a lookin' I found a piece of 16g. steel (bent into a channel) as seen on the work bench in the above pic
IDK that just seemed a bit too thin
...but, this piece of ~14g. seems ta "fit the bill" much better
* It's NOT a pristine piece
...but, I think I can "work with it"
...& try it as a prototype
If it works out well, I'll get some nicer 14G. steel :thumbsup:
First drilled out the inner curve (gook 'ol Step drill bits...again) ;)
Then, went ta cuttin' :cool:
A little while later, it started raining harder
...shortly after I removed the "winterization"...of course o_O
Then, it started a stormin' :eek:
So, whilst I wasa "forced" ta take a break
...I did some doodlin'
...& drew up some Patriotic flames...I guess you'd call 'em :thumbsup:
I'ma thinkin' that something like this would/maybe look kinda kool, on the racer :auto:
* Maybe just tattered ends (instead of flame flickers)
...or maybe even separated stripes "freely" flowing in the breeze :2guns:
** Folks feel free to "play with"
...& expand on this concept...if ya want ;)
*** If it looks kool
...maybe I'll put 'er on the racer :cheers2:
I did a bit more work on the Caliper bracket (prep work before bendin')
Put 'er in the Vise (aligned with the bend line)
The Impact Persuader (hammer) did the rest
Looks like this ;)
Should "go" about like this, on the Spindle
Top view
Should intersection with
...& bolt to
...the Spindle's Steering Arm
...like this :thumbsup:
Test fit of Caliper, on the Bracket
...Caliper & Bracket on the Spindle
...& of Caliper & Bracket, on the Spindle, with the wheel mounted
Another view
...mounted on the racer
Another view
IDK after workin' with & assembling everything
...this 14g. steel now doesn't seem "beefy" enough
So, I looked & found some 12g. steel
...& went ta cuttin' a (2") strip off of the end
12g. piece, marked for trimmin'
* A "trick" to make makin' these a bit easier, is to drill the Spindle hole first
...then, align, the template for markin' ;)
** Because "if" this hole doesn't get drilled exactly in the center
...everything WILL be "off" :eek:
After trimmin'
...we go, back ta the Vise
...for bendin'
After test fit & alignment check, I went ahead
...& bolted the Caliper Bracket, to the Steering Arm of the Spindle
Another view
* Why does the Caliper Bracker need ta be bolted to the Spindle? :unsure:
This is so, when the Brakes are applied (Caliper clamping down on the Rotor)
...the Caliper & Bracket don't "spin" with the wheel :cheers2:
Havin' some issues with these plastic/nylon rims :furious2:
Four hours later
...& still havin' issues with these stupid plastic/nylon rims :mad2:
IIRC T warned me about this...a whilst back :oops:
Another silent movie
...but, I don't think ya need me ta verbally explain it to ya :thumbsup:
Well...me & Ducky wasa thinkin'
After makin' several Caliper brackets
...tryin' ta overcompensate (in different ways) to make these wheels work
Ima "kickin' dirt" & mumblin' :mad2:
Ducky says:
Time ta "take a brake" & think about it :cheers2:
Four hours later
That looks like the same issue i had with WTC. The minibike wheel I got was manufactured crooked. I had to take it to the lathe and make it straight.
She always wants to take a break. Adapt and overcome! Switch to steel wheels and consider the plastic ones a failed experiment!
Hey Denny,
Yup, that's what I'ma thinkin' too :thumbsup:
Dis-mountin' the hub(s) & tire(s) & tube(s) off of these stupid Plastic/nylon rim(s) :huh:
On these white rims the first thing ya gotts ta find is
...the rim 1/2 that has the hole, for the valve stem
Once the valve stem is inserted thru the hole
...I always screw the cap on
So, the valve stem can't pull out or fall back, thru the hole
...whilst your "fiddlin' around" with mounting the other rim 1/2
Once assembled, I aired 'er up ~30 PSI
Tire says (up to) "40 PSI cold" :cheers2:
Hey WTR,
I have one of those rims too
...hope it doesn't have issues...too
My buddy T (Master Hack) did some (lathe) work
...where the hubs mount
...trying to "true" these rims up
BUT, IIRC he said that he had trouble with the material (plastic/nylon) flexing
This is how they normally look (stock)
Now that we are working with these white rims
...I gotta get out the custom hubs, T made to work with these rims
These hubs "ride" on a 5/8" spindle (just like the black plastic/nylon rims)
...& are designed to use the same rotors
So, this should be a pretty easy transition :thumbsup:
Wheel spacers
We need "spacers" between the hub (bearing)
...& the Caliper mounting bracket/spindle
To maintain the proper distance between the hub & Caliper bracket
...& ta keep the hub from rubbin' against & (potentially) damaging the Caliper bracket
These are standard hardware store washers for a 5/8" bolt (flat & lock)
But, we gotta keep in mind that the bearing has (2) 1/2's
The outer section, that the wheel "rides on"
...& the inner section, that the spindle "rides on"
We can't have a "spacer" that "bridges" (& basically connects) the (2) sections
...like the big/flat washer would do
...'cause then, the inner section, couldn't spin independently, from the outer section
So, the Lock washer would be the better choice
But, a Lock washer has a "locking" feature
...& we don't want that feature, in this situation
So, let's do a bit of modification :thumbsup:
Inserted it in the vise
Used the adjustable, manual, hand bender
...ta do some adjustin' ;)
Yup, like that :2guns:
Lookie what I found on the side of the road (stainless steel refrigerator door)
...musta fell out of the back of a scrapers truck
...free materials :thumbsup:
Figured this may be a good choice of material ta make the front, inner "saddle" out of
...as it wont need paintin'
As/such there is no paint ta "wear off" durin' use
...& should look pretty kool...too :wai:
So, I measured & marked, a piece ta use for the inner "saddle"
Cut 'er out (cut off wheel)
Gently pried 'er off
Jualla! :sifone:
Here is the backside, after scrapin' any foam residue...off
Gonna use some of the 18g. steel ta make the rear inner "saddle"
...as it doesn't need ta be cosmetic (will be hidden by the seat)
...but/also, needs ta be pretty strong
As the propulsion will be "pushin' against it"
...the suspension "pad" will be "pushin' against it"
...the roll bar will mount to it
...& the shoulder straps, for the seatbelts, will mount to it too :thumbsup:
The plan
...drawin' with measurements
After cuttin' out the piece for the rear inner "saddle"
...I noticed how much "flimsy" (technical term) the SS piece was compared to the 18g. piece
So, on second thought
...it just doesn't seem to be "up to the task" :oops:
So, I went ahead & made an 18g. inner "saddle" for the front ;)
Let's start off with the front inner "saddle" :cheers2:
I did a (3) part bend
...each bend ~1/8" apart
...ta try-n-make a curved bend
...rather than a corner bend ;)
Test fit looked pretty good :wai:
So, I drilled some holes
...& bolted 'er in :thumbsup:
Another view
A view from up underneath :thumbsup:
* Notice the "shadow" of the inner "saddle" is a bit bigger?
** Looks pretty solid/secure...ta me :sifone:
Here is a view under the floorboard :)
*** Also, notice the "shadow" of the inner "saddle" here?
...& how most everything "bolts" thru it (even the axle's outer "wrap around" mounts? :cool:
