Building my special cart
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Left rear. Or middle. Easy alignment for the Drive wheel and engine power.
Middle makes for easy controls. I think
Rail rider
Inmate # 3192016
Planet earth ( the flat one)
:idea2: I could also go with the middle tire. :stir:
---------- Post added at 05:52 PM ---------- Previous post was at 05:49 PM ----------
Which wheel drive is it going to be?
I have 6 to chose from. Decisions, decisions
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
So tell us what you got for a sprocket. pics.
I always have had live axle Karts. But what you are trying to do is a very Common relatively easy "One wheel peel" Go kart Drive.
Some one here should shoot you a simple fix.
Rail rider
Inmate # 3192016
Plan "C"
Cut a 5" disc and drill a 4" bolt circle, weld that to the spindle... Use any 4" bolt circle sprocket in the future. Ez
---------- Post added at 05:26 PM ---------- Previous post was at 05:24 PM ----------
I've used those, it's the guide disk that makes it a problem.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Exactly. you just need some spacers between the Disk and the Sprocket.
Depending on your Bolt holes there is a drum for a band brake that bolts to sprockets.
Oops now I will get you "haunted" about brakes.
Rail rider
Inmate # 3192016
Brakes only slow you down before the impact... Mentally
insert
Hellions flaming car gif here.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Perfect I did not know you knew. Yes, what you want is a Typical Mini bike set up.
---------- Post added at 05:42 PM ---------- Previous post was at 05:41 PM ----------
Old post. But NO! Chancer, you're totally wrong, they last.
For 2 minutes. :p
I dunno Profit got 15 minutes yesterday, and Only 90% wear! :p
Jfive
Great falls Montana
Got called into work yesterday at 1am to put a train car back on the rail that derailed. Got to drive our 125t crane on the rail to lift the car. Was gonna take a picture of the wheels it uses as they'd be perfect for this kinda project. It's a mantis crane.
Rail rider
Inmate # 3192016
Yes a set of those would work great. Or a set of the smaller ones they use for the pick up trucks. If any come up missing it wasnt me...
