Flyinhillbilly
The great cornholio
Which wheel drive is it going to be?
Hmm, good ? Any recommendations.Which wheel drive is it going to be?
Left rear. Or middle. Easy alignment for the Drive wheel and engine power.
Middle makes for easy controls. I think
I could also go with the middle tire.
I have 6 to chose from. Decisions, decisionsWhich wheel drive is it going to be?
Thanks man, that was bad move I was going to do...with welding it to the spindle.I do what I can!![]()
Brakes only slow you down before the impact... MentallyExactly. you just need some spacers between the Disk and the Sprocket.
Depending on your Bolt holes there is a drum for a band brake that bolts to sprockets.
Oops now I will get you "haunted" about brakes.
It will be interesting to see if there is actually a use for those.
On an actual Go kart they last about 1 hr! No Kidding..
And on a Dolly (hand truck) they are completely worthless.
Old post. But NO! Chancer, you're totally wrong, they last.
For 2 minutes.![]()
Well, I better get a rocket engine to get me the 50 miles (one way) . That I'm building this thing to go on . If I only have 2 minutes run time.Old post. But NO! Chancer, you're totally wrong, they last.
For 2 minutes.![]()
Got called into work yesterday at 1am to put a train car back on the rail that derailed. Got to drive our 125t crane on the rail to lift the car. Was gonna take a picture of the wheels it uses as they'd be perfect for this kinda project. It's a mantis crane.
