Personally I'd prefer an abrasive disc because while they wear down and can shatter given certain circumstances... a metal carbide blade will go dull and begin to kickback aggressively and can warp from heat dull or not.5200 RPM max or the 10” cutoff wheel is like 6100 rpm
The trade off is pretty negligible overall but the abrasive discs tend to be higher rater than carbide tipped blades.
The other advantage is that the abrasive discs can be thinner. Thinner cuts means less material wastage in the cuts, and there's also the fact that the abrasive discs tend to cut smoother and leave less to debur
