Bobs 2024 Build Off Build
I have no clue how this happened. I messaged Amazon to see if I could split a payment between two cards, one being a gift card.
The answer was neigh, but somehow was given a $10 credit for asking which was used to get some 8oz of cutting fluid.
Free Fluid! He was wrongly accused.
Cut him loose.
Spring has sprung. The grass is ‘ris.
I wonder where the the birdie is?
DIY POTTING MEDIA
Base Mix (By Volume)
50 % Canadian Sphagnum Peat Moss
35 % Aeration (Pumice or Perlite)
15 % Worm Castings
For 1 cubic yard of base mix…
100 gallons of peat moss (13.5 cu ft)
70 gallons of aeration (9.5 cu ft)
30 gallons of worm castings (4 cu ft)
~200 gallons per cubic yard.
~ 7.5 gallons per cubic foot
Added to 1 cubic yard of base mix…
15 lbs Gypsum
10 lbs Soft Rock Phosphate
10 lbs Basalt Dust
7.5 lbs Oyster Shell Powder
7.5 lbs Bone Meal
5 lbs Cottonseed Meal
2.5 lbs Potassium Sulfate
100 grams Iron sulfate
50 grams Manganese Sulfate
25 grams Zinc Sulfate
15 grams Copper Sulfate
10 grams Borax
Happy Gardening.
I began rewatching Prison Break today. I used to like it a lot. Since I’m starting to put my frame together, this scene was fitting.
I guess the 5 speed Harbor Freight Benchtop Drill Press stepped pulley doesn’t exist in the outside world.
I think it’s about 1/2” bore. (12-14mm)
OD of unit about 80mm
5 stepped
8mm V-belt width.
I see lots of 150mm OD.
Or units for larger width v-belts.
The stock belt says K-660 1601
Smallest pulley is about 28mm
Largest pulley about 65mm
Height of unit about 53mm
I like m&m s with almonds. But w&w s taste better!
I wanted to try to get a third of the same stepped pulley units to make things simpler, but there are other ways. And that setup wouldn’t get 750 rpm down to 250. It would only about 375 rpm.IMG_5431.jpeg
I just think a drill press that can run at 375 RPM to 6000 RPM is more useful than one that varies from 750 to 3000 RPM.
If y’all have drill presses, what speeds can it turn?
The recommended speed for this 1.5” TCT bit seems to be around 220 RPM.
1.375” - 250 rpm
1.75” - 190 rpm
1.5” (38mm) should be around 220 rpm? No?
This second chart suggest maybe 360 RPM for 38mm bit in plain steel, but the range is 300-600 RPM for 31mm - 40mm range of bit size.
The slowest speed on my drill press is 760 rpm.
Getting that down to 380 RPM puts me a lot closer to “ideal”speed based on the charts for 1.5” hole saw for steel. The 600 rpm on the chart seems to be meant for the smaller end of the 31-40mm range.
760 RPM seems to only “work” for about a 1” max diameter hole saw in steel. And too fast to use for stainless even at 1/2” diameter.
A point on the circumference of a 1.5” hole saw moves at 5 ft per second at 760 rpm.
A point on the circumference of a 1.0” hole moves 3.3 ft per second at 760 rpm.
Just showing how a larger diameter hole saw must spin slower for the “tooth to material” relative velocity to remain constant.
A bear and a rabbit are taking are taking a poop in the woods. The bear turns to the rabbit and asks, “Do you have problems with poop sticking to your fur?”
The rabbit said, “No.”
So the bear wiped his butt with the rabbit,
Side Quest:
Grow apple trees on your third story balcony.
Tom Hardiness Zone 6b
Tom Foolery Zone 58G
Cross Pollinators
Dwarf Root Stock (25% size of Regular Size)
