2020 - Excalibur Electric Racing kart
Thanks fellas! :cheers2:
Sat 'er on the ground
…& installed the wheels :thumbsup:
Boom! :2guns:
...we have a "roller" :wai:
Ima gettin' excited :bannana:
I can (almost) feel the "wind in my hair" already :cool:
I started wiring up the batteries :thumbsup:
...using the same red 10g. wire that I used for wiring the CB :cheers2:
* Most wire has an inherent resistance, in the material their made from, to the "energy" flowing thru 'em
...as such, the longer a "wire" is, the more resistance it has
So, the "cables" used for connecting batteries "in series" should all be of the same length
...this way the "energy" flows thru 'em all consistently (no "bottle necks" so to speak)
But, this presents a problem :mad2:
We have (2) batteries next to each other, on (1) side of the kart
…& the other (2) batteries, next to each other, on the other side of the kart
So we need a short cable (~6") connecting (2) batteries
...a longer cable (~20") to cross over to the other side
...& another short cable (~6") connecting the other (2) batteries
I would think, the proper solution would be to make all (3) "cables" (~20")
...but, that seems like a lot of extra/unnecessary wire :ack2:
So, Im thinkin' I'll try (2) 10" cables & (1) 20"
Where is my buddy Sid? :huh:
...he would have some input on this situation
** Also, when workin' with higher voltages it's best to use insulated tools
I went to use a flat head screw driver to bump/coax a Spade terminal on to it's terminal
…& accidentally "shorted" (2) battery terminals :ack2:
The screw driver, the terminal & my finger all "took a hit" :oops:
*** Note to self, DON'T do that again :furious2:
A couple of days ago, I gave the floor board a chrome "look" (chrome spray paint)
...but, it really looks more like polished aluminum :cheers2:
So, now it's ready to install :thumbsup:
…& the seat too :2guns:
I made up some straps to secure the batteries :cheers2:
The black one is from a kids car seat
...but, the buckle didn't seem too strong
The yellow one is made from "ratchet strap" material
...but, the "cam action buckle" didn't "grip" too good
...so, I tried/added a different buckle :2guns:
* I'm tryin' (2) different type straps & buckles, as a test
...just to see how well they will work
...& also, how long they will last :cool:
** I also wired up the reverse switch :thumbsup:
I took 'er out for a Maiden Voyage (first test ride) :wai:
...but, Ima not gonna say no more :stir:
Um, yup :thumbsup:
...we have a video :2guns:
https://www.youtube.com/watch?v=yUIPAdOexXo
Let me know what you'all think :cheers2:
Cool beans!!! :wai: That was an awesome test drive. It looked like everything worked the way you hoped it would. Another excellent build :thumbsup:
looks pretty Skippy. do you know if it is track legal?
If there was a class for electric karts, I am sure it would probably be legal
Next, I want to install a meter to monitor the energy level in the battery
…& also, the power usage :thumbsup:
A PZEM-051 should do the trick :cool:
(more info)
http://www.diygokarts.com/vb/showthread.php?t=42102
It displays the Voltage (V) of the Battery pack
...the Current (A) Amps being drawn from the battery
...the Power (W) Wattage of the component drawing power
…& (records) the Energy used in (Wh)
* I believe the Wh (Watt-hour) "function" displays the energy that's already been used, out of the pack
…which should help us calculate the "available" energy, that's still left in the pack :cheers2:
I've been thinkin' about where & how, to mount the meter
It's gotta be easily visible
...but, also not "obtrusive" or in the way :huh:
Was gonna use the upper steering bushing mount bolts to attach a bracket, that would hold the meter, just in front of & above the steering wheel
...but, it's gotta be in some kind of a container
…it's gotta look kool too ;)
Sooooooo, a "worn out" old pair of HF hearing protector/ear muffs "caught my eye"
…& I said, Hmmmmm :rolleyes:
I dismantled the "muffs"
…just "stuffed" the meter into (1) of the rubber ear "pads"
…& then, "stretched" the "pad" back onto the (red) outer housing
The meter, in it's new housing, mounted easily on to the "headband"
...but, it wasn't very sturdy (kinda "floppy") :ack2:
Then I thought, why not just mount 'er right on the steering wheel
...that should be pretty sturdy
…& also, easily visible :2guns:
Karts of Kaos
the many mowers guy
Wisconsin
landuse said:
If there was a class for electric karts, I am sure it would probably be legal.
I meant the frame. I did not know if you were allowed to build a frame or if you have to buy it.
Hmmm, that's a good question :thumbsup:
I figured there were height, width, length & weight requirements/restrictions
...but, I never thought about "if" the frame needed to be professionally designed &/or manufactured :cheers2:
* Hopefully FH will "chime in" with some info :popcorn:
...he knows about this stuff :2guns:
I used the "upper" of the (3) steering wheel mounting bolts, to mount the meter housing :thumbsup:
Then, to wire up the meter, I first drilled a 3/8" hole
…added a rubber grommet
…& then, "run" the (3) wires thru :cheers2:
The red wire (B+) supplies the voltage info to the meter
…& powers the meter too
* The voltage indicator wire on this SC is "switched" (which means that it's turned on/off with/when the SC is "switched" on or off)
The black wire (B-) supplies the negative (-) info, to the meter
…& also, completes the circuit, for "powering" the meter
The yellow wire (P-) supplies the "differential signal" (amp draw) to the meter
I "ran" into an issue :huh:
I turned the circuit breaker on
…& then, flipped the on/off switch to "on"
Then, I heard the speed controller "click on"
…& meter "lit up" too :thumbsup:
But, when I looked at the meter,
...the voltage was only showing ~1/2 of the "actual voltage" of the battery pack :huh:
Well, thinkin' it thru, it seems that I forgot to install a "jumper wire"
...between the (2) negative (-) terminals :cheers2:
Yup, that's more better :2guns:
Took 'er for a ride :auto:
...to get some data, from our "new" meter :thumbsup:
Here is some footage of the meter, during the ride :cheers2:
https://www.youtube.com/watch?v=KAQ0nAXr0cU
I accelerated from a "dead stop" :cool:
…& the first thing that I noticed was the huge voltage drop (almost 6V) on "take off" :smiley_omg:
The next thing that I noticed was the Wattage, which showed ~ 1,720W
...the Max Wattage, that I saw (from this 1,000W motor) during this ride was ~1,760
The Amperage showed ~37.69A
…& the Max Amperage was 38.26A
At the end of this "test ride" the meter showed the voltage level, down to 48.9V
…& that I had used ~190Wh of energy, from the batt pack
