2020 - Excalibur Electric Racing kart
I made the mounting bracket on the pedal a bit "off set" to align with the thumb throttle :thumbsup:
This also, helps to keep the "linkage assembly" further, off to the side
…& "outta harms way" :cheers2:
The cable "slides" thru the small hole in the end of the "connector"
...the "barrel head", on the end of the cable, fits in the "loop"
…& a "stop nut", on the other end of the cable, engages/catches the "lever" on the thumb throttle :cool:
The throttle pedal "throw" seems to be ~3" :2guns:
I tried a spring "in-between" the pedal & thumb throttle
...but, it was still kinda "floppy"
So, I bent a couple of pieces of 1/4" rod into a U shape
...to use as/for "pedal stops" :thumbsup:
The brake doesn't seem to need one
...but, the throttle was kinda floppy (when released)
…& also, the pedal could put "too much" pressure, on the thumb throttle, when "floored" or fully applied :huh:
Yup, she's good-n-solid now (in both directions) :wai:
…& no "pressure" on the thumb throttle (it's just "along for the ride") :cool:
I re-installed the floorboard, steering assembly & seat again
…so, I could actually/physically, get in/sit down & make sure everything "worked together" :thumbsup:
The seat feels comfortable
...& firm
The steering height
...& distance from driver seems good
The brake pedal/action is super firm
...& it "would/should "stop on a dime"
The throttle pedal is not difficult to actuate (sometimes springs are kinda "stiff" just before "stretching")
…it returns/springs back nicely
…the petal positions seem good too
(from zero throttle thru full throttle the drivers foot is not in an awkward position)
…& the thumb throttle (electronic component) seems safe "tucked" off to the side :cheers2:
It looks good to me!
Thanks! :thumbsup:
It's been kinda rainy & humid lately :huh:
…& we got a lot of "bare" metal "exposed"
I guess it's time to "seal 'er up" :wai:
So, I took 'er all back apart again
…meticulously smoothed & cleaned every piece (every "nook-n-cranny")
…& wiped 'er down/gave 'er a "bath" in paint thinner :2guns:
Then, sprayed a good coat of Self Etching Primer
...looks kinda "faded" Army Green
...or even Olive Drab (Hawkeye-M*A*S*H*) :cheers2:
While the primer was dryin', on the chassis, I started roundin' up electrical components
…& made up a dash board :thumbsup:
It'll have a circuit breaker/main cut-off switch
...the on/off switch
…& the forward reverse switch :cheers2:
Ima gonna use a 48V 150A Buss MRCB circuit breaker as both a "resettable" fuse
…& the main cut-off switch
A "rocker style" switch will activate/turn on or off the speed controller
The "duck bill" switch will "signal" to the speed controller the, drivers, "intended direction of travel"
* Flipped forward, indicates ya wanna to go forward
...& "flipped" toward the back will "reverse" the direction of travel :2guns:
Power Wires
The leads coming out of the SC (speed controller) for a 48V 1,000W motor use big (~10g.) wires for the "power wires", these bring the "power in" from the battery (+/-) & also, to send "power out" to the motor (+/-)
…& then, they use smaller (~20g.) wires to send/receive "signals", like on/off & reverse :thumbsup:
To use for the "power wires", I got some red (10g.) wire for the positive (+) side
…& some black (10g.) wire to connect the negative (-) side
For the "signal wires" I got a kool lookin', blue "cable" that has (9) individual/colored (20g.) wires within it
I figured, I'd "run" the bigger "power wires" first (more cumbersome)
…& then, "run" the smaller "signal wires" (easier to "tuck in") :cheers2:
So, starting @ the front right batteries positive (+) terminal, I ran a piece of the red "power" wire from it, to the "Line" side of the CB (circuit breaker)
…& then, ran another piece from the, "Load" side of the CB to the SC
* The electrical "current" must flow in the designated direction, thru the CB, for it to "function" properly :cool:
** Since both of these wires, look/are the same
…will "run" down the right side of the kart
...& will also, connect to the CB, I "color coded" the ends, to easily indicate which one is the "power in" (red) coming from the battery
...& which one is the "power out" (yellow) going to the SC :2guns:
Before "runnin' the signal wires, from the dash board to the SC (speed controller)
...we gotta figure out how & where we are gonna mount the SC :thumbsup:
* We also gotta keep in mind that "test #2" will use (2) motors
...which means we gotta provide mounting "space" for (2) SC's :cheers2:
So, I was thinkin' to just mount a "panel" across the "roll bar/seat back" right behind the seat
….takin' it a "step further", I figured I could kinda "box in" the bottom, to protect & support the plugs & connections
…& then, I figured why not "box in" the top too :2guns:
* This "double boxing" will make for a good-n-strong "structure"
...so, it can be made from lighter materials :wai:
So, I'ma gonna try-n-make it outta some 16g. aluminum (same as the floor board & battery trays) :cool:
...but, first I made a "test piece" outta some cardboard ;)
** I even folded/bent it in the sheet metal bender, for nice-n-crisp fold/bend lines
Yup, that should work :sifone:
...just gotta make 'er outta metal now :popcorn:
Next, I used the card board "mock up" as a template to mark the metal (another old sign) :thumbsup:
* Before cuttin', I drilled some holes where the inside cuts will intersect (for nice/clean "inner" corners) :cheers2:
Smoothed/deburred the edges, a bit :cool:
…& then, took 'er to the bender
1 1/2" from top bend to 90*
...then, slide 'er out another 1 1/2"
...& then, bend 'er to 90* again
For the bottom, I flipped 'er around
…& simply, repeated the procedure :2guns:
Did a quick test fit
…& added some screw holes for mounting :thumbsup:
Before paintin', I had to drill some holes to "run" the plugs/wires thru
The big ~1" hole is for the "signal" wires
…& the smaller ~3/8" hole is for the "power" wires :cool:
* I went ahead & drilled the holes, to "run" the plugs/wires thru, for SC #2
...but, they should have been the same on both sides :huh:
Both of the small holes should have been on the left
...& both big holes should have been on the right :mad2:
** Noticed it, while it was dryin' :smiley_omg:
Oh well, I'll deal with it later :2guns:
I popped a 3/8" rubber grommet into (1) of the small holes
…& a 3/4" grommet into (1) of the big holes :thumbsup:
Then, poked the wires/plugs thru
…& used a couple of screws to "bolt 'er down" :cheers2:
Nice-n-clean "look"
…plus, good-n-sturdy :2guns:
The connections will be protected from "all" sides
…& there's also, easy access by either removing (4) screws & tilting the panel
...or by removing the seat :cool:
Thanks fellas :thumbsup:
So, I "ran" the kool blue (9) wire harness to the rear "connection box"
…& connected the wires to their corresponding plugs :cheers2:
Also, I think I came up with a clever idea for protecting, insulating & mounting the shunt
...for the PZEM-051 (100V 100A) electrical monitoring system :wai:
I got some 1" vinyl tube (with some kool braiding)
…& simply "slid" the shunt inside (fits nice-n-tight) :cool:
Then, it can easily be mounted to the bottom of the "connection box" :2guns:
Finishin' up the wiring :thumbsup:
I didn't like the "open terminals" on them "big" power wires :huh:
...so, I covered 'em up :cheers2:
Tidying up some "small stuff"
I measured, marked & cut some "spacers" (1) for between the sprocket & bearing
...& (1) for between the sprocket & wheel
Also, (1) "spacer" for between the brake drum & bearing
…& (1) for between the brake drum & wheel
Then, cleaned 'em up & sprayed 'em satin black :thumbsup:
* To be able to "tell" the difference between the (2) "spacers" for the left & the (2) for the right, I marked the (2) for the left side with a small "notch" :cheers2:
While they were dryin' I started some re-assembly :wai:
I installed the "trays" (1) on each side
...& the batteries (2) on each side :2guns:
Before mounting (1) of the ZY-1020 motors, I had ta "switch" the drive sprocket
...from the one that came on it (for #25 chain)
...over to a Power Curve Sprocket (for a #35 chain) :cheers2:
* Remember the bolt, that hold's the sprocket on these motors, have left-hand or "reverse" threads :thumbsup:
I used a pair of plyers (opened "up big") to "grip" the sprocket
…& an impact driver, to remove the bolt :cool:
Then, reversed the procedure, to install the "new" one :2guns:
(he he, double reverse) :smiley_omg:
Also, installed the sticker :D
...gotta "represent" :sifone:
I "mounted" the motor on the mount (version #1)
…& then, "mounted" 'em on the kart :thumbsup:
*notice the kool black "spacers" :cheers2:
Then, I brought 'er out & put 'er on the worktable (ta get 'er used to the outdoors) :cool:
…& started re-installing the steering components :2guns:
