Update! Got the topside of the frame mostly welded in, made a new intake pipe out of aluminum using the stock rubber coated boot that lowers the carb and shifts it slightly to the right. Aluminum welds aren't the best looking, but they should hold fine. Also started laying out the wiring to gauge what needs shortened or extended, etc. I welded some "C" channel on the underside of the frame tubes as well, and it really made it stronger. With some oil and fuel I could easily test fire it, too! Hope to soon! Ergonomic wise, it's a lot more comfortable to sit on than I thought it would be, and it doesn't look horribly goofy with me sitting on it.
Still going to brace the frame up/gusset as well, but it's a good place to test the engine out and make sure it's worth continuing forward.
Ordered up some pegs, a front axle, tethered kill switch, and a few other parts for the brakes, etc. Those should show up soon.
-MrTurbo
