2017 - !Arriba!
Looks a bit cramped but it sure runs great.
Set up like them "old school" karts
...knees up in your chest -n- all
But, it's not really cramped
just
...short sweet & to the point
...& yes, it runs very good, even off road :thumbsup:
* I can't wait to experience the performance with the 2nd motor
! ARRIBA ! :2guns:
Here is another Desteny rides video
She has had some steering issues
It seems that
...by only running (1) motor (on the left side)
...with lots of power/torque
...& having such a short wheelbase
...& with the rear wheels being so far forward
...& with the frame being so light
the Arriba kart tends to (with her on it, not so much with me)
...lift the front wheels & lurch toward the right
...& doesn't like to turn left at all
...especially on grass
https://www.youtube.com/watch?v=e6LV0A3l6jo
First, I switched the #25 chain sprockets on both motors with Power Curve sprockets for #35 chain :thumbsup:
Then, I removed the left (MY 1020) 48V 1,000W motor & replaced it with a ZY 1020 48V 1,000W motor & I also installed a (matching) 48V 1,000W ZY 1020 on the right side
I also installed a (matching) 72 tooth sprocket & a piece of #35 chain on the right side
The drive sprocket & the driven did not line up
...looks to be ~1/4" off
Used the chop saw to cut some assorted spacers
Then I got 'em all adjusted up :2guns:
https://www.youtube.com/watch?v=ynqP0iDZoh0
Now we gotta hook up the electronics :thumbsup:
Removed, the MY 1020 speed controller, off of the back cover
...installed the (2) ZY 1020 controllers
...installed a 50A circuit breaker
...& the charge port that came with the motor kit
Connected, an on/off switch (on the dash) to each of the controllers "lock" plugs
...a motor to each speed controller (wired so the left one spins CCW & the right one spins CW)
...the (2) thumb throttles
...& the charge port plug
I grouped
...the (2) battery positives (+) together
...& the (2) battery negatives (-) together
(the ones coming out of the speed controllers)
Then, connected a piece of black 10g. wire, to the 2 wire negative junction
...& ran it to the battery packs negative (-)
Then, connected a piece of red 10g. wire, to the 2 wire positive junction
...& ran it to the input side of the 50A circuit breaker
& then, another piece of red 10g. wire from the circuit breaker to the battery packs positive (+)
I mounted the left thumb throttle on the left side of the steering wheel & got it all adjusted so both throttles rotated the same (had the same throw)
...then I noticed (it's upside down) :smiley_omg:
Both of my thumbs are not on the left side of my hands
Easy fix, just flipped it over :2guns:
Double checked everything, propped 'er up & made sure that the wheels were off the ground
Flipped
...the circuit breaker "on" (nothing popped or is smokin') :wai:
Turned the left switch "on" (still lookin' good)
...& gave the left thumb throttle a twist
Yup, :thumbsup:
Turned the right switch "on"
...& gave the right thumb throttle a try
Yup, :2guns:
Time for a test drive :cheers2:
https://www.youtube.com/watch?v=WC2EPqBMkJA
Me & the kids rode 'er around for at least 20 min or so before dinner
...then plugged the charger in when done :2guns:
I think we should install some "wheelie bars" :thumbsup:
...before the battery box disintegrates :ack2:
But, how "high of a wheelie" do I want to pull/sustain :roflol:
I set the front of the !Arriba! kart on a tire to check "ride height"
…front axle ~9"
Naw, that ain't enough
How about up on (2) tires?
...front axle height ~18"
What about the battery box?
...looks to be ~ 2" (off of the ground)
Yup, that should work :thumbsup:
So, a couple of ~3" wheels should work :thumbsup:
Mounted/bolted them to a piece of steel
...so their removable/changeable (if necessary)
…& to help keep 'em aligned
TT540
Newb
Huntsville, AL
The tricky part to a wheel bar is the BAR part. Those new wheels have to extend out at least 2 feet. Reason is you create a whole new "wheelbase" when they are in use. And the rear wheels then become the front wheels. With front wheel drive you have torque steer. And with the rear wheels 4 inches behind you will turn and turn quick.
Also, with them that close, you could very easily flip alllll the way over because now those rear wheels are a pivot point.
Wild ride for sure. Knee pads and elbow as next time. Lol
