2017 - !Arriba!
After splitting the steering support
used a piece of scrap steel & vise grips to help hold & align the pieces
a little tack weld here
a little tack weld there
Then double check everything
...measurements
...alignment
...angles
...& even by eye (gotta look good) :thumbsup:
Steering wheel options:
...from a car
...off of a riding lawn mower
...a standard go kart replacement
...make some handle bars
Nope, not gonna work
This one is set up like old school style
...with your knees way up high
I'm thinkin' dragster style
Butterfly wheel
Guess, I'ma gonna hafta make one :thumbsup:
put a couple of kool bends in some ~2" x 1/8" steel
Layed the bent metal on the bench (hump upward)
put a couple of 3 1/2" pieces of pipe on each side of it
with
...~1/2" hanging below
...& ~2" sticking above, for the thumb throttle(s)
A couple of spot welds on the back side to hold 'er together
(don't want a bunch of build up back there, that's where ya grip)
flipped it & welded the front side up good :thumbsup:
cut a ~2" piece of scrap pipe (used it right down to the nub) for the mounting hub
drilled a 1/4" hole thru it & cut off the scrap/excess & welded it on
Boom!
one custom made
Butterfly Steering Wheel :2guns:
Steering assembly
the steering shaft is a piece of 5/8" x 13 3/4" steel rod
For the bottom (foot)
I wasn't sure about the length
so, I made (2)
Both are pieces of 1/8" steel
(1) @ 2 1/2" the other @ 3 1/2"
drilled 3/8" holes in one end of each one (to attach tie rod ends)
& 5/8" holes in the other end of both (to attach to the bottom of the steering shaft)
The 3 1/2" is the winner :thumbsup:
squared 'er up with the steering wheel & welded 'er up
The floor pan is next
Had some left over expanded metal
(1st) piece is 26" x 16" (just wide enough to cross frame rails)
bent it @ ~110* angle (12" for the seat & 14" up the back)
...with a couple of C-clamps & some 2 x 4's
(2nd) piece is 6' x 16' (good enough to prop your feet up)
Did a little trimmin' & a little roundin'
then
Some clampin' & some weldin'
then
Some more trimmin' & more roundin'
4 hours later :ack2:
Almost ready for primer :thumbsup:
Gotta do a few more things :thumbsup:
Safety stuff ya know
First
Brakes
Lets go, Big Wheel Style :2guns:
...short, sweet & 2 the point
Start off with a piece of 5/8" rod & a couple of mounting brackets
Next
With the rear wheels positioned as far forward as we have them
that means we are gonna have a wheel/sprocket spinnin" @ :idea2:
well lets do the math :cheers2:
...if the motor does 3,000 rpm's
& we have a 7.2:1 gear ratio (3,000/7.2 = 416.66)
that means the wheel/sprocket will be spinnin" @ ~400 rpm's
right near our elbows
So, ya, I think we need some elbow protection :2guns:
Added a couple of left over, slightly bent bars between the driver & the wheel (may add fenders or ? IDK)
More on the brakes
cut a couple of pieces of 1/8" x 2" steel ~ 3" long
rounded'em up a bit
poped 'em in the bender
@ a 30* bend ~1" from each end
Yup!, that should do it :2guns:
After running the 5/8" rod thru the mounting brackets & centering it with the wheels I spot welded the brake pads on
Removed the wheels & welded them on good
After cooling a bit, put wheels back on to figure handle placement
then added a ~6" piece of pipe for a handle
spot welded it, removed the wheels again & welded 'er on good too
Now, we got brakes (an E-Brake anyways)
Big Wheel Style :thumbsup:
Rear wheels
(2) 6" x 4" split steel rims
(2) tubes (split rims don't hold air too good)
(2) 15 x 6.00 / 6 tires
Take 'em apart (rim halves)
Insert a tube into a tire
air it up a bit (so it can't get pinched between rim halves during assembly)
use soapy water around the tire bead, so the rim will slide into tire (also aids assembly)
put valve stem thru hole in rim
stand up, add second rim half (aligning bolt holes)
insert bolts with lock washers & nuts
torque 'em down good
air it up to ~15 lbs. psi
then release the pressure/deflate (so tube can self align)
Air it back up to ~15 lbs. psi
...& done :2guns:
Cleaned, wire brushed, smoothed, & de-burred
...the spindles, tie rods steering shaft, butterfly wheel
...& the entire frame from end to end
...flipped it over & repeated the above procedure
Then, a final cleaning
...gave everything a bath in paint thinner
...then another quickie wipe down with fresh rags doused with fresh thinner (to help make sure I didn't miss anything)
Finally, ready for some primer :2guns:
Oops, forgot about the battery box
Old aluminum road sign (free sturdy & lightweight) :thumbsup:
Cut off a piece
Popped it in the sheet metal bender
1" lip x 3" down x 6" across x 3" up x another 1" lip
It sits on pieces of angle steel in front & in back
Should support 'em nicely :2guns:
Now, to seal 'er up & make her look purty
Goin' for/with Gold :thumbsup:
gave everything several light coats (not really coats - a bit lighter)
then a nice gloss coat :2guns:
KingCobra
TROLL CRUSHER INC.
TROLL TORTURE ROOM
...measurements
...alignment
...angles
I spose in that first photo you had the engine running?? :D Looking great though!! I like your braking system but the only down fall I see is that you are limited to that size tire for ever.
  • 00000000000000000000000000000000000000000000000000000000000000000000000000000000000.jpg
Something musta been runnin' :thumbsup:
Probably jittery from grinding/sanding
Yup, limited to (1) tire size
Went that way for (2) reasons
(1)...the 15 x 6.00 / 6 is common on the front of riding lawn mower.
I have lots of 'em & their easy to come by otherwise
...& there are many tread patters available even smooth/slicks
(2) ...I wanted to try 'em on an electric kart
It seemed to be a happy medium between the smaller 10" - 12" tires & the bigger 16" - 18" tires
Were gonna find out :2guns:
All the loose parts are painted gold
...& the bottom side of the frame too :thumbsup:
So, after ~24hrs.
I did some light assembly
...inserted the battery box thru frame (front bolted down with rear axle bolts, the rear lip is bolted down with (2) 1/4" lock nuts & bolts (wiped clean)
...mounted the rear axle with (wiped clean) washers & lock nuts
...mounted the spindles with (wiped clean) lock nuts & bolts
...mounted the steering shaft with (greasable) plastic bushings
...mounted the steering wheel with (wiped clean) 1/4" bolt & lock nut
...added the tie rods (nut & bolt also wiped clean)
Because,
I want it to look finished overall
...sometimes, things get scraped a bit during assembly
...& after assembly you have unpainted hardware everywhere
...& you don't want to spray bolt heads & such (mess up your nice paint job)
So, now I'll give 'er a nice (top coat)
By doing it this way I think it has a more professional/manufactured look
...everything is coated/matching
...& all scrapes during assembly are covered as well :2guns:
Rounded up some wheels that will work up front
They are off a (super heavy duty) old fun kart.
They have Timken style roller bearings that were for a 3/4" spindle.
All my karts have 5/8" spindles.
These bearings look pretty krusty anyways
So, I'll just get new ones :thumbsup:
Two days later
...still can't find these (stupid) bearings with a 5/8" ID anywhere
So, Plan B
...clean 'em up with petroleum based solvent (gasoline)
..& add 5/8" ID x 3/4" OD bushings
But, the bushings don't seem to fit in the bearing too good
...have ta do the old freez'em trick
...shrink 'em up a bit & tap 'em in with a block of wood
Yup, that'll work :2guns:
