2017 - !Arriba!
The mixture was totally gold, in the jar :thumbsup:
...but, to my surprise, the green seemed to "appear" with the first coat :smiley_omg:
…& then, the gold started "popping" with the second :2guns:
The sprockets turned out pretty kool too :thumbsup:
Now for re-assembly :thumbsup:
First, I mounted the (driven) sprockets to the wheels/hubs
…& then, mounted them onto the kart
Next, I installed the motors
…& also, mounted/adjusted the chains :cheers2:
I "signed" & dated the bottom of the battery box :thumbsup:
Then, added the (4) 12V 12AH SLA's (put 'em on top of a foam rubber mat)
…& strapped 'em down with (2) 24" HD wire/zip ties
All of the electronics attached to the "bonnet" cover are "modular"
…& pretty much still intact
So, I just had to re-install the On/Off switches
…& the thumb throttles
…& re-run the wires
…& then, get everything re-connected :2guns:
I am switching the front wheels :thumbsup:
The previous ones are part of a matching set, off of an amusement kart
…& I may use them on something else :cheers2:
* The tire tread on these "other wheels" even kinda matches a little better :wai:
...but, the rims are gray :ack2:
So, a little scuffin' (to "knock off" the shine)
...a wipe down (with de-greaser)
…plus, a little maskin' (cut some cardboard to fit nice-n-tight)
…& Boom!, we have white wheels :2guns:
I thought it was gonna be Gold-to-Green
…& it's actually Green-to-Gold
...but, it's kool :thumbsup:
And...here she is :wai:
* I also added one of the seats that I "made up" back in the winter :thumbsup:
gegcorp2012
Alabama
Great work on the details, painted sprockets, matching wheels and the seat. Looks really nice.l!
Sent from my SM-J700T using Tapatalk
Something was missin' :huh:
:idea2: Chain guards :thumbsup:
There's not really a lot of sprocket/chain exposed
...but, their still a rotating gears
…& their right there on top kinda accessible :ack2:
So, I rounded up some thin steel (~18g.)
...marked & trimmed it up a bit
...drilled a 1/4" mounting bolt hole
…& bent the tab to ~90*
Then, took 'er out side & "skillfully" bent 'er around a fence post
Yup, looked good :2guns:
...so, I made one for the other side
A little smoothin' & cleanin' :thumbsup:
...then, some primin' & paintin' :cheers2:
...& Boom!, we got some kool little chain guards :2guns:
