Polaris
American ingenuity at its finest. The wheels, not the cat...
Thanks! :thumbsup:
I got a set of rotors, to use with the 48mm adapter hubs that I have
...but somehow, I ordered 160mm rotors (instead of 180mm rotors)
...& the spindle brackets are made to work with 180mm rotors :mad2:
& also,
I noticed that I bent the brackets backwards :huh:
...so, the left caliper went on the right side (but, upside down)
...& the right side went on the left (also, upside down) :furious2:
So, back to the drawin' board
I bent up a couple more spindle brackets
I needed (3) lines, on the same level, on both pieces
So, I used a 3/4" wide piece of steel to mark 'em all evenly
Left side V1 / right side is V2
* Notice the difference in the position of the caliper bolt holes?
I re-established the Ackermann angle :thumbsup:
Marked 'em at the 2 1/2" & 3"
...& whittled down some of the excess material off of the spindle brackets
Left side is before & right side is after some whittlin' & smoothin' :cheers2:
Used the whittled down bracket, as a template, ta make the other side match
Ta lighten 'em up a bit more, I added some holes, ta remove some material
...& them holes may even help provide some ventilation, to the brakes ;)
Next I gotta install the spindle/axle(s)
Anyone have an opinion on what grade of 1/2" bolt should be used? (Grade 3 or 5 or 8?) :unsure:
Hey Master Hack,
How much Loctite should be used or is recommended for bearing retention?
...just a drop & let it spread around?
...a light coating, on both surfaces?
...or slather it on & just wipe off any that squeezes out?
Also, I would assume that some should be applied to both sides, of the spacer material?
So, in between the bearing & spacer
...& also, in between the spacer & hub :thumbsup:
I got some of both (grade 5 & grade 8)
...but, stronger is better (right?)
...so, I went with the grade 8 (1/2" x 5") bolts (& their golder) :p
Before attacking one of my V2 spindle brackets with the welder, I stuck a 1/2" bolt into one of the V1 spindle brackets
...& did a couple of test welds 🤓
Not too bad I guess :unsure:
According to the heat marks, on the other side, it seems like we got some decent penetration :cheers2:
Also, had an idea o_O
Yup, there's one for each side :thumbsup:
What the heck are those things?
...& what are they used for?
Well, Ima glad you asked :thumbsup:
I wanted/needed to weld the spindle bolts, to the spindle brackets, on both sides ta make 'em stronger
...but, I also needed a nice flat surface for the bearing (or washer) to sit/ride against
...& I didn't want to have a clean up nightmare
...&/or mess up the spindle
...so, I made up them little guys
They go over the spindle, to give us a nice flat bearing/washer surface
* I used a piece of conduit to use as a temporary spacer
...to bolt the spindle bolt down good-n-tight
...& protect the spindle/axle from "splatter" during welding :cheers2:
Up close view
* Them openings, will allow me access to the bolt
...so, I can weld the bolt to the bracket
...& also, to the little spacer (making them all "as one") ;)
Kinda like this
Excellent! Grade 5 would have been plenty strong, but overkill is mo bedder! Who doesnt love a grade 8 bolt?
Even stronger is a socket head cap screw (SCHS). Just for future reference.
Yup mo bedder
...& they are gold :thumbsup:
Dry fit 'em (again)
Another (closer) view
* Notice the nice-n-clean spindle/axle :sifone:
Looks pretty good ta me :2guns:
...so, after some clean up, I hung 'em up & wiped 'em down
Then, sealed 'em up with some Satin Black spray paint
Back side
I finally received my order for a bottle of Loc-Tite 680 (green) High Strength Retaining Compound :cheers2:
Assembled a tray of parts 🤓
First, I cleaned up the hub (inside & out)
...& inside of the adapter hub too
Applied a small bead around the perimeter of the hub (& spread it around)
...& a light coating inside (on the threads) of the brake rotor adapter too
Then, put 'em together with the green hub rings
...& some Stainless Steel hardware (bolts, washers & Loc-Nuts)
The brake rotor (adapter) is now firmly attached (mechanically & adhesively) ;)
I also, put some of the retaining compound on the threads of the bolts (under the Loc-Nuts) for added durability :2guns:
I did about the same procedure ta "glue" the bearings into the hubs :thumbsup:
Looks like this
...& this
Just to be sure the bearings were setting "true" I ran a 1/2" bolt thru each wheel & then, let 'em set for a day ;)
The next day
...& were ready ta roll :2guns:
Looks great! With the shim material in there, the bearings fit the hub nicely.
Thanks! :2guns:
Yup, it's almost like a machined fit, thanks to your expert advise :cheers2:
I also, used some of the Loc-Tite ta "glue" some Chineseum bearings, into the Boss Tubes, that I got off of some old scooter wheels
These should help 'er ta turn a bit smoother than just havin' a 1/2" bolt run thru a couple of 1/2" holes
Bottom side
Let them sit for a day
...& then, dry fit the spindles, again
Another view
...& then, the wheels, again
...& calipers, again
Top view
Steering Stops
I didn't incorporate any steering stops on to the spindles
...&/so, it seems like they turn too far :huh:
I used a stock go kart spindle for a turning range comparison 🤓
* The turning range seems ta be ~45* (each way)
** Notice the arm of the stock spindle "bumps" against the mounting bracket, creating a "stop"
So, (1) side provides a "stop" when turning in (1) direction
...& the other side provides the "stop" when turning the other direction :cheers2:
So, here is starting off at pretty much going straight (90*)
...& we want them to go to about here (45*)
Clamped a piece of steel "stop" on the Boss Tube
...& compared it to the stock spindle again
Looks pretty close ta me ;)
...but, I'ma gonna just tac them in for now (just ta make sure) :thumbsup:
The morning dew has been initiating an unwanted patina on the chassis :ack2:
...so, after lots & lots & lots of clean up (basically "four hours later")
...& "boy 'O boy" do my hands & arms ache :huh::furious2::mad2:
Then, I sealed 'er up, ta stop all of that patina BS "in it's tracks" ;)
...& make 'er look purty too :bannana:
* Set 'er up on an angle, ta be able ta paint up under
...& in all of the nooks & crannies, first
Another view
Then, set 'er down nice-n-level
...& went at 'er again :thumbsup:
Another view
...& even another view :p
* Notice, I didn't seal up the Boss Tubes (&/or their attachment areas) :cheers2:
They are just tac'ed in place
...& I want to do some testing, ta make sure of steering functionality, before weldin' them on good-n-solid
...& then, sealin' them up :2guns:
I'd like ta point out the 5-Point seat belt harness mounting brackets :thumbsup: (as required in the rule book) 🤓
This pic shows the (2) side seat belt mounting points (top & bottom)
...& the mount for the crotch belt too (over on the right side)
Close up view of (1) of the side mounts
...should be good-n-strong :2guns:
The upper holes, in these dual-purpose brackets, are where the shoulder straps will mount
...& the lower holes are for mounting the seat
I'd also, like to point out the control cable mounts
In this pic (on the left side) is the dual brake cable mount.
(the rule book requires an independent brake cable, going to each front brake calipers)
...& on the right is the front cable mount, for the throttle :thumbsup:
Here is the rear cable mount, for the throttle
...& the throttle itself, mounts on this little "pearch" ;)
