What the heck are those things?
...& what are they used for?
Well, Ima glad you asked
I wanted/needed to weld the spindle bolts, to the spindle brackets, on both sides ta make 'em stronger
...but, I also needed a nice flat surface for the bearing (or washer) to sit/ride against
...& I didn't want to have a clean up nightmare
...&/or mess up the spindle
...so, I made up them little guys
They go over the spindle, to give us a nice flat bearing/washer surface
* I used a piece of conduit to use as a temporary spacer
...to bolt the spindle bolt down good-n-tight
...& protect the spindle/axle from "splatter" during welding
Up close view
* Them openings, will allow me access to the bolt
...so, I can weld the bolt to the bracket
...& also, to the little spacer (making them all "as one")
Kinda like this
