@Chiron TL-34
You should always have these extra parts when owning these small engines.
All gaskets
Head
Side cover (green or black only)
Carb gaskets and insulator plates
Valve cover
Shims
for end play and correct valve spring installed height
Crank
Cam
Valve springs
Crank and cam shims keeps the crank and cam from walking.
This keeps every thing inline nice and titey, less resistant, less drag, less wear and tear on the connecting rod, a much smoother rotating assembly.
Valve spring shims keeps the correct spring pressure.
Too little will cause valve float and not let the rpm go up and can drop a valve.
Too much will cause premature cam wear.
There's no such thing as "self adjusting" valve springs.
Or "one size fits all" valve springs.
Every head I have ever set up needed shims for the valve springs.
These are mass produced parts, and no 2 heads are the same.
These small little things is the difference in a run of the mill, NIB tiller motor, and a good, strong running, reliable gokart engine.
If you need help finding cam shims, jus yell. Not too many places carry them.
