With Master Hack's assistance, it looks like I'ma B needin' some R8 bearings
...so, got 'em on order & they should be here, next week
Now, lets move on to another delima
I need to add brakes to both front wheels (as per the rule book)
...& I'd like to use disc brakes
...but, how do you install brake rotors onto bicycle wheels?
Well, the rear wheel that I'm gonna use, has 34mm fine threads, on the outside of the hub, for mounting the freewheel unit
...& now, upon looking around, noticed that many mountain bikes use this same method for mounting rotors like this:
https://www.ebay.com/itm/175716099348?var=475102205451
...using a threaded on adapter, like this:
https://www.ebay.com/itm/194966693368
OK so, the front wheels, that I'm gonna use, have some fine groves
...but, don't have any threads on the outside of the hub, for mounting an adapter
...but, it looks like I could, maybe, put some there
Another view
The threaded hub measures out to be 34.95mm
From doing some research, it seem that the threads for these freewheels & disc brake adapters are 34mm
...but, not sure exactly what pitch
Then, looking at available Threading Dies, it seems like they are available in 34mm x 1mm pitch, 1.5mm pitch & 2mm pitch
Whadda you'alls think?
...does there seem like there is enough "meat" on that hub, ta add some threads to?
