Polaris
So, I'ma thinkin' I'ma needin' 30mm OD x 13mm ID bearings
Does this sound right?
...& do they make such a thing?
For reference, I looked up to see if 30mm x 13mm bearings were even made or available 🤓
...but, didn't find much :huh:
Then I searched for 29mm x 13mm bearings
...& found a bunch of options, like this: :thumbsup:
PEER 7R8 Radial Ball Bearing 13mm x29mm x 8mm 1/2"id, 1-1/8"od, 5/16"w, SHIELDED
https://www.ebay.com/itm/1662935503...u/UkceHh+acnXZJeiP7iH3NvsQ==|tkp:BFBMzpSJlMhi
They list a size conversion chart
Size (conversions)
  • 13mm x 29mm x 8mm
  • .51 x 1.14 x .315"
  • 1/2" x 1-1/8" x 5/16"
  • Bore: 1/2"
  • OD: 1-1/8"
  • Width: 5/16"
Where l’m from .510 x 1,14 and 1/2 x 1 1/8 are NOT the same size! Must be a china thing?
Will the 1/2 x 1 1/8 (.500 x 1.125) fit your wheel?
if thats the case then an R8 is what ya need.
I had to go to (3) stores to find that stupid (LR44) battery :mad2:
They couldn't make that compatibility list any bigger? :huh:
Well, we have power now :thumbsup:
Hub measurement
Hub depth measurement
For reference, Bearing Race measurement
Decimal please! Yeah l can convert it, but l want to see it. I think we’re dealing with an inch series.
actually all i really need is the ID of the hub socket.
We already established the axle/spindle is a 1/2 bolt, correct?
The drive wheel, has a freewheel unit, that threads onto the hub
The outer hub on the freewheel unit has a sprocket for use with bicycle chain (1/2" spacing) & a ~2 1/4" OD
...& we need a bigger sprocket & for use with #35 chain
I picked up a 72T - #35 sprocket (~8 1/2" OD)
...but, the center hole is only ~1 1/4" ID
So, I set up a drillin' station (with a 1/4" hole in the middle)
Then, used a 1 1/4" hole saw ta center the sprocket (with the 1/4" center hole) on the drillin' station
After centering, I, clamped the sprocket "in place", on the drillin' station
...& removed the hole saw
Then, I used a 2 1/4" hole saw, ta drill/saw, a bigger center hole :thumbsup:
After a bit of clean up & deburrin', it fit pretty nicely, over the freewheel hub :wai:
Here's the other side :sifone:
I used a caliper ta help "fine tune" the centering of the sprocket (on/with the freewheel unit) :thumbsup:
From every direction (a couple of times) just ta be sure :cheers2:
Then, drilled bolt holes, in the sprocket, to align with every (3rd) tooth) on the freewheel unit
Then, used (6) 5/16" x 1" bolts (with loc-nuts)
...& bolted 'er together good-n-tight :2guns:
Yup, :thumbsup:
I would rather have the front wheels mounted standard go kart style (only supported on one end)
...which calls for a minimum axle diameter of 1/2" in the Electrathon America rule book ;)
6. Axles supported at both ends must have a diameter of at least 3/8"(10mm).
7. Axles supported only on one end must have a diameter at least ½"(12mm)
Here is our drive wheel (with tire mounted) :thumbsup:
I'doubt these Fenix (China-cheap) tires are gonna last very long (especially under racing conditions)
...but, we'll see ;)
The green tire on the black rim, looks pretty kool :2guns:
With Master Hack's assistance, it looks like I'ma B needin' some R8 bearings
...so, got 'em on order & they should be here, next week :popcorn:
Now, lets move on to another delima :huh:
I need to add brakes to both front wheels (as per the rule book)
...& I'd like to use disc brakes
...but, how do you install brake rotors onto bicycle wheels?
Well, the rear wheel that I'm gonna use, has 34mm fine threads, on the outside of the hub, for mounting the freewheel unit
...& now, upon looking around, noticed that many mountain bikes use this same method for mounting rotors like this:
https://www.ebay.com/itm/175716099348?var=475102205451
...using a threaded on adapter, like this:
https://www.ebay.com/itm/194966693368
OK so, the front wheels, that I'm gonna use, have some fine groves
...but, don't have any threads on the outside of the hub, for mounting an adapter
...but, it looks like I could, maybe, put some there ;)
SAM_0145.JPGAnother view
The threaded hub measures out to be 34.95mm
From doing some research, it seem that the threads for these freewheels & disc brake adapters are 34mm
...but, not sure exactly what pitch :unsure:
Then, looking at available Threading Dies, it seems like they are available in 34mm x 1mm pitch, 1.5mm pitch & 2mm pitch o_O
Whadda you'alls think?
...does there seem like there is enough "meat" on that hub, ta add some threads to?
Takes a LOT of torque to turn a 34 mm threading die. You need to look at thread depth also. What material thickness will remain? Theres charts out there…
Ya need to be sure to get the die started straight. Thats a tough job without some mechanical assistance.
Discouraging reply
...but, honest :thumbsup: thanks :cheers2:
May be better & easier to get a couple more of the rear wheels (with the outside threaded hubs)
Thinking it thru, this concept should work, for adding a brake disc to the left front wheel
...but, not for the right front one :huh:
Because when the brakes were applied the left front would tighten the adapted, on to the threads :wai:
...but, the right one would just unthread itself from the hub :furious2:
So, the right side would need left handed threads (another $30.00 tap) :mad2:
...but, I havent seen LH threaded brake disc adapters
More thinkin' required
...we'll get back to it ;)
Atlanta, GA
Fortunately aluminum is pretty soft. You might be able to turn a new thread, really you're just trying to get a more depth in it right
Egor has been busy polishing R8s. They were REMed then he tossed em in the vibe with walnut shells. I told him this was a clasified project. He’s thinkin Mars rover or sumpthing. He doesn’t need to know….
anyway looking good! I hope you negotiated a good deal….
Red loctite would work for that. You’re not stopping a truck. A machine shop could cut some threads on there without the agony of hand threading, possibly.
IDK about Loc-tighting a brake rotor on o_O
I've always been kinda leery about adhesive bonds
...& have way more faith, in mechanical bonds :thumbsup:
My local machine shop raised their minimum fee from $40.00 up to $75.00 about a year ago (like everything else) :huh::furious2::mad2:
Did them bearings come as a DIY kit? :roflol:
Workin' on a CAD rear fender :thumbsup:
Another view
I designed it to cover the entire area (inside of the frame) which should help protect the motor & electronics from any moisture (wet track or puddles)
...&/or road debris
I made 'er out of some 20g steel (from a metal box, that was the housing of an old dishwasher)
Bended the sides up first
Then, worked on the shape
Turned out kinda like this
Another view
That front "lip" will tuck under & bolt to, the motor mounting plate :thumbsup:
