Karttekk
There should be no reason why your kart wouldn't run properly once it's together. The last step should be installing the belt. Attach your driven pulley on the jackshaft, slip the belt over it, slip the back half or engine side half of the drive pulley on the engine, slip the belt over the crankshaft then attach the outer half of the drive pulley. If you can put the belt on with the drive pulley fully assembled the belt is too big. If you watched the video I sent about measuring for the correct belt you'll see what I mean. Good luck, waiting for the results.
