Gorgeous machine! What'd it cost you?
thats a lot of money to pay back
Nice job.
Blue have you bought the POR15 yet? A quart will go a long long way. You may need more than one quart for sure. But not to much more. Then you will be stuck with a 2nd quart of por15 that will dry up as soon as you open it. Well no shelf life anyway.
I would buy one quart. Then buy the por15 black 6 pack of cans.
This way you can use the quart. And if you have open a 2nd can you can just open one of the 6 cans.
So say you all are done with por15. You used the quart and two cans out of the 6 pack. Now you have 4 smaller cans for future projects that will not go to waste.
I have found the 6 pack to be the best ever as far as por15 stuff. It saves you big money over the long run. And you do not waste any. Also lets you not have to paint everything in one day for the paint will go bad.
If you already bought the two quarts. Then use plastic film when you put the lid back on. Then store the can upside down. This way when you open the can the thick skin is on the bottom and not the top. If you use no plastic you will never open that lid again no matter how hard you pry. POR15 will weld that can closed for good.
Just another por15 hint from the por15 freak.
MAke sure you beef up the seat mounts on that floor. Or make sure it's done solid. You do not want your sent ripping out in crash. Or run your set belt to the solid part of the floor.
thats a nice job
its coming on good
id definitly strengthen those mounts beyond standard
cant hurt to
at least u will have invaluable experiance after this project along with a very good knowledge of how your truck and cars in general work
i like the idea of storing the can upside down, would apply to all paint cans?
by pasitc film do u mean Glad wrap or something more solid?
couldn't you just cut the seat belt bolt head off, drill it out and then use a nut and bolt?
It has little shelf life. I find it not as good once it open for a few days. A few weeks no.
Also never paint from the can with a brush. POR15 derections will tell you this as well. Once the brush hits the can it brings in moisture. Never shake por15 always mix it by hand creating no bubbles.
I hear guys will poke two nail size holes in the lid on each side. Then drain the por 15 into cups. Then they rubber plug the whole. They say this gives it shelf life. I have not tried it though.
I find my local auto paint store carries por15 now. Check with them they price may surprise you. It did me.
Also shelf life will depend on if it's a rainy day or not. And how much moisture get into the paint.
If you can find it locally you can buy one quart at a time. I think one quart may be enough. But never did large jobs like that.
The new metal looks much better! That thing really is rusted EVERYWHERE isn't it? LOL
It looks like you got yourself a new welder! If so... Welcome to the Hobart family!, I couldn't be happier with mine, I finally bought an argon bottle so I'm practicing my aluminum MIG skills.
Keep that shiny new metal coming!
ive checked out tons of things on this truck so far. ive had a lot if it apart. i definitely have learned alot!
this is true. i may do this. IDK if i can fit my grinder where the bolt is. but ill see. if not i will probably try drilling the whole thing out
my local auto store does have it. i didnt check thr price when i was there but ill definitely call them
i think i will need more than a quart because i want to get some spots of the underside of the bed too. i googled how much it would take and most people used 2 quarts to do the frame twice
[/B]
Were they spraying or brushing?
Also grind that rust away where the new metal meets the old.
Maybe build a flatbed? Might be easier/more fun to work with a little new steel rather than chase the tin worm away some more.
Granted, I did an entire new floor in the bed of my F100, but that truck has sentimental value, and I'd probably never do it again to a truck this new.
EDIT: whats up with that swirl thing next to your front door lol
