Bluethunder3320
- Messages
- 5,677
- Reaction score
- 36
Very simple 30min task with 2wd, unfortunately a bit more complicated with 4wd, requiring some special tools. You have a Haynes or a Chilton's for this truck, right? It should explain what you need to do and what tools you'll need to borrow. If you don't have a manual, go buy one now.
i have a chiltons manual. ill look that up later
my dad told me that people have used roofing tar for undercoating the frame and body. the only thing is you want to wear the worst clothing you have when painting the tar on because the tar seems to get everywhere and is hard to remove.
hmm not sure if i wanna do that lol, painting sounds less mess and neater and i could probably get tighter spots better
well i worked ALL DAY and finally got the bed detached from the frame.
it was an adventure for sure, i first tried to remove the (front) fuel tank so i could get to the bed bolt, but it only spun. i couldnt put a wrench on the other size because i needed both hands to wrench on the ratchet (with vice grip attached
so i had to cut both straps with my grinder. i didnt want to have to do that because duh, its a fuel tank... but i did it and the fuel tank was loose.
then i had to remove the fuel lines which pissed out fuel on me, that was not too hard... the wiring came off easy, but i had to cut the venting tube. not a big deal, ill replace it along with another section that is in bad shape. the filling tube took some time to pry off but no big deal either.
then i put a 4 foot cheater bar on about a 8" ratchet, and tried to break the bed bolts free. they made some ear bleeding squealing sounds then just turned and turned.....
i couldnt figure out where the head of the bolt was so i had to go online and figured out that i needed to remove the bed liner
then i welded large nuts on the dish shaped bolt heads and put a adjustable wrench on them. they would hit the front of the bed and stop, while loosening, which is what i want
the first bolt came out clean, then i went to weld the nut on the second. i ran into major welder problems....
i have the 90 amp flux from harbor freight and a home made metal stand which allows me to use a 10 pound reel of wire. the bed of the truck was grounded, so was the metal stand, so was the welder, so was the hole in the welder that the wire passes through. it made a lot of sparks and melted all the plastic tubes on the feed motor and screwed up the liner. took a while to fix it but i got it working again and got that nut welded on.
so the second nut broke the bolt. doesnt matter. but i smashed my hand
i disconnected the wiring for the tail lights and license plate lights then the bed was completely loose!!!!
the front bolts were the only still in tact, the middle were rusted through the bed, and the rear...... well there is no rear frame anymore hahaha
