truck talk
Bluethunder3320
Gorgeous machine! What'd it cost you?
$500. :ack2: thats a lot of money to pay back
what makes me feel better is, the hobart 125 costed $350, but the gas upgrade kit costs $150, so a total of $500. the hobart 140 comes with the gas kit, so its a better welder for the same price in that sense...
i worked my a$$ off today got most of the passenger side done! im planning on putting the door back on tomorrow
bighead
Pacific Northwest USA
Blue have you bought the POR15 yet? A quart will go a long long way. You may need more than one quart for sure. But not to much more. Then you will be stuck with a 2nd quart of por15 that will dry up as soon as you open it. Well no shelf life anyway.
I would buy one quart. Then buy the por15 black 6 pack of cans.
This way you can use the quart. And if you have open a 2nd can you can just open one of the 6 cans.
So say you all are done with por15. You used the quart and two cans out of the 6 pack. Now you have 4 smaller cans for future projects that will not go to waste.
I have found the 6 pack to be the best ever as far as por15 stuff. It saves you big money over the long run. And you do not waste any. Also lets you not have to paint everything in one day for the paint will go bad.
If you already bought the two quarts. Then use plastic film when you put the lid back on. Then store the can upside down. This way when you open the can the thick skin is on the bottom and not the top. If you use no plastic you will never open that lid again no matter how hard you pry. POR15 will weld that can closed for good.
Just another por15 hint from the por15 freak.
MAke sure you beef up the seat mounts on that floor. Or make sure it's done solid. You do not want your sent ripping out in crash. Or run your set belt to the solid part of the floor.
Bluethunder3320
Nice job.
thanks!
i havent bought it yet. good idea on the small cans. so i have to paint the entire thing in one day? i thought i have resealed the sample can before, i dont remember.
and great idea on turning over the can!
cheapest POR15 i can find is off amazon, $33 a quart. ill see if they have the small cans too.
i tried to remove the seat belt from the rocker panel, (passenger side), with a star bit, ratchet, and 4 foot cheater bar. i managed to twist the star bit into a spiral! that bolt is never coming out. ill have to figure out how to weld around it
fowler
Bullsbrook West Aus
thats a nice job
its coming on good
id definitly strengthen those mounts beyond standard
cant hurt to
at least u will have invaluable experiance after this project along with a very good knowledge of how your truck and cars in general work
i like the idea of storing the can upside down, would apply to all paint cans?
by pasitc film do u mean Glad wrap or something more solid?
bighead
It has little shelf life. I find it not as good once it open for a few days. A few weeks no.
Also never paint from the can with a brush. POR15 derections will tell you this as well. Once the brush hits the can it brings in moisture. Never shake por15 always mix it by hand creating no bubbles.
I hear guys will poke two nail size holes in the lid on each side. Then drain the por 15 into cups. Then they rubber plug the whole. They say this gives it shelf life. I have not tried it though.
I find my local auto paint store carries por15 now. Check with them they price may surprise you. It did me.
Also shelf life will depend on if it's a rainy day or not. And how much moisture get into the paint.
If you can find it locally you can buy one quart at a time. I think one quart may be enough. But never did large jobs like that.
Bluethunder3320
thats a nice job
its coming on good
cant hurt to
ive checked out tons of things on this truck so far. ive had a lot if it apart. i definitely have learned alot!
couldn't you just cut the seat belt bolt head off, drill it out and then use a nut and bolt?
this is true. i may do this. IDK if i can fit my grinder where the bolt is. but ill see. if not i will probably try drilling the whole thing out
my local auto store does have it. i didnt check thr price when i was there but ill definitely call them
i think i will need more than a quart because i want to get some spots of the underside of the bed too. i googled how much it would take and most people used 2 quarts to do the frame twice
Bluethunder3320
so i have to fix the bed up,
suspension is back on, needs more welding though
crude at this point but its still strong... i could probably drive it like that
r97
Measure twice cut once
Massachusetts, USA
The new metal looks much better! That thing really is rusted EVERYWHERE isn't it? LOL
It looks like you got yourself a new welder! If so... Welcome to the Hobart family! :D, I couldn't be happier with mine, I finally bought an argon bottle so I'm practicing my aluminum MIG skills.
Keep that shiny new metal coming!
Bluethunder3320
if you looked at the truck front on, it looks brand new. ill have to post a pic of that angle. the paint has held up amazingly well. theres a part of the bed that has no metal at all, only paint! and it doesnt look too bad.
at this point im not going to go into detail and fix the rust on the bottom of the door, or the cab corners. im going to paint it with POR15 to stop any more rust but it will stay the way it is. its a beat up truck, i have to take care of it, but i cant make it perfect and glossy. after all its a truck, its made to get dirty
when its back together it will at least be structurally safe and have a sturdy floor.
my welder is a Hobart 140. it came with the gas kit but i dont have any $$ for gas bottles yet so im flux core welding still.
newrider3
Colorado
Maybe build a flatbed? Might be easier/more fun to work with a little new steel rather than chase the tin worm away some more.
Granted, I did an entire new floor in the bed of my F100, but that truck has sentimental value, and I'd probably never do it again to a truck this new.
Bluethunder3320
im going to replace that rusted out piece of the bed with a 2x4. just want to put the bed back on and be done with it.
i have a bed liner so the little holes dont really matter
bighead
Could save you a buck or two Blue.
Have not checked prices from POR-15 but thought I would pass this on.
Use code JULY4FSO and receive FREE Shipping on any Retail order placed from Tuesday July 3rd thru Monday July 9th 2012. Remember to use code JULY4FSO on the checkout page to recieve FREE Shipping on your order.
por15.com
bighead
Were they spraying or brushing?
Also grind that rust away where the new metal meets the old.
Bluethunder3320
[/B]
2 quarts would be brushing.
i looked at the POR15 website and it is $50 per quart, so $100 total. amazon is the cheapest place i could find its $33 per quart and with shipping its around $70 i believe. thanks for the coupon though!
mrfreyguy
Buggy Almost Done
Iowa
Did the same thing to my old truck before I sold it. Save yourself the headaches and just throw a flatbed on it.
Bluethunder3320
with this truck i move my bikes, logs, brush, leaves, scrap metal, i need something with sides plus this truck will be driven pretty much as a daily driver not always with loads. and i want the bed to match the cab
i dont think its going to be a big deal to get it back on.
EDIT: whats up with that swirl thing next to your front door lol
