picken up an engine #3
Kenny_McCormic
Kartless....
Michigan Troll
First it needs to be measured to see how big of a bore it needs (there should be a ring of untouched metal at the very top of the bore, is there a ridge between this and the rest of the bore?), then you have to buy the parts and have it bored to fit them or bore it yourself with a flex hone. I would recommend you have a small engine shop do it for you.
sayre315
Rupp enduro
Oklahoma
its a cool bore (aluminum) threres no steel sleave
i'll have to find a machine shop
how much should i bore and how much would you say they would charge?
oscaryu1
If you're going to bore the block, those rings I sent you will be useless. They're standard bore.
You'll have to go oversize... oversize piston and rings.
I've had a couple of scratches on my cylinders. However, only 1/20 of them extended from the top to the bottom of the bore. Most stopped where the piston was at the very bottom... (BDC?)
Did a quick hone, broke it in on Castrol HD30, added a bit of Restore w/ CSL, and it runs absolutely great. One pull starter. You saw the video sayre :)
sayre315
Rupp enduro
Oklahoma
where can i get CSL?
oh i went to o'rily auto parts and got a flywheel puller(3 arms) valve lapper and spring compressor
oscaryu1
LOL @ flywheel puller. That's just a standard (probably 6") 3 jaw puller. Flywheel pullers screw into the flywheel and pull it out. You'll pretty much break it with a 3 jaw puller...
All you need is to hit the end of the crank, while using a pry bar and it'll pop right out. Seeing as someone didn't weld or JB weld it on :D
Restore w/ CSL (that's what it's called) is a oil additive. I can swear it works. The trashpicked lawnmower gained so much compression you slowed down pulling it, as with my other engines that started easily.
It's in a little silver can. Here's a picture:
oscaryu1
NO! NEVER sandpaper! This isn't a weedeater... this is a 4 stroke Briggs 2 horse.
Generally, I use this:
You can find those at automotive stores of Harbor Freight (look for it yourself, they have NO IDEA what it is. They lost a customer because of it... I overheard the convo lol)
Remember, lube it when honing. Honing oil or just plain motor oil works fine.
sayre315
Rupp enduro
Oklahoma
are those some kinda stones on there?
do i spin it with my hands?
does it have springs on it so it expands and puts pressure on the bore?
jr dragster T
Cold place
No you will NEVER be able to spin it fast enough with your hands. You use a drill, As you can see at the top of the honer. And Yes it has springs to push out on the bore a little bit.
oscaryu1
The engine restore stuff is basically leaded oil, the oil burns on the cylinder walls and leaves lead deposits in the scoring.
CSL (IIRC) = Copper, Silver, Lead.
So there is already lead in there. But hey, it works. As long as you don't run it on like 100% of that stuff, you should be fine.
sayre315
Rupp enduro
Oklahoma
well i have carb problems
t wont start :( and theres gas leaking outa the part where it atatches to the tank and on the choke end
also i think the needle nut is stripped, would that keep gas from getting to the engine?
2or3wheels
Minneapolis Minnesota
sound like needle and seat issues. as far as outa tank, thats sompletly differnet. wait if this is a briggs then a few gahskets and your good, put a .61 cent gasket in my 4 horse briggs runs like a charm.
sayre315
Rupp enduro
Oklahoma
so would i need to get a new needle? i know for sure its stripped pretty bad
oh, and i when to Advaced Auto parts taday and bought some liquide gasket and some of the restore stuff but i looked at the honing device and it was $30!!!
oscaryu1
It's about $20 shipped on eBay.
You can buy rebuild kits on eBay. Include stock jet, needle, ect.
thatkidrob
wow i have the same exact engine, good job on it though, mine wouldnt start either, i had to tear it down, clean rebuild, check the points, lol, only thing different is mines a 2 hp (sson to be more when im done with it, lol)
oscaryu1
His IS a 2HP :roflol:
