New Go-Kart Builder
Keep in mind that the decorative (non-structural) tube they use in that instructable is DEAD thin. Way thinner than you are going to use.
For tire sizing, the LAST number is rim diameter- IE 13x5-6. 13 is the overall height in inches, 5 is the width at its widest point (sidewall bulge, not tread) and it fits a 6" diameter rim.
DS13
Annoying the Neighbors!!!
Elysburg, PA
Go-Kart Maniacz
Also if I buy these and replace the bearings with High speed ones will they work? I mean what could go wrong? I might go get some today
4.10x3.50-4 means- 4.10 sidewall height, 3.5" wide, 4" rim diameter. Approximately 12" diameter. Please use the EDIT button to avoid rapidfire posts.
Go-Kart Maniacz
Thanks for answering. Also I picked up an awesome used chair for 25$. We unscrewed the roller and now it is just the chair. we spray painted it grey in the picture. Next we are going to do the final coat black. Also the arm rests I plan to paint blue along with the frame of the Kart:
http://farm9.staticflickr.com/8528/8569838605_1658a757d9_b.jpg
also if I replace the bearings in the other tires will they work?
spyder808
McKinney, TX
doubt the integrity of the thin walled rim would handle well once you get weight, speed, and side pressure from turns ... don't risk your safety over a few bucks
Evilmongoose
Those same wheels are working very well for me, just buy spares just encase. I think they are cheap enough for us who are just starting off.
