New Go-Kart Builder
Go-Kart Maniacz
Is making a 2-wheel drive go kart very difficult? Right now I am designing my go kart and need to know how to set it up. If any one could help that would be great!
Some might say that 2wd (live axle) is easier to set up and build than 1wd. Instead of having to buy a special hub and cram the stuff into a very tight space, you have the entire span of the axle to put your sprocket and brakes...
Go-Kart Maniacz
Thanks for the quick reply! The one thing I need to figure out is how to make the sprocket not so close to the ground, so if I go over bumps it wont hit the ground? Is their an easy way to do it so the sprocket is not hanging down right in the middle of the go kart?
Go-Kart Maniacz
We are building it now!!!!! Tell me how to do it. can we put the sprocket next to the tire even with 2 wheel drive?
With a live axle, you are free to put the sprocket anywhere along the axle. Close to a frame member (bearing) cuts down on leverage on the axle (less likely to bend), and you are correct- closer to a wheel means less chance of dinging it off an obstacle.
DS13
Annoying the Neighbors!!!
Elysburg, PA
Yep black pipe is regular steel with a nominal WT so yeah.
FYI: galvinized steel is hazardous to weld. The zinc fume that comes off it during welding is poisonous to you.
Sch40 black iron pipe is not the best choice for a go kart. It's heavy and thick for what it is. However, it will do in a pinch and if you are new at building it's probably better to be too heavy and strong than light and weak.
FWIW- Such pipe is sized according to the Nominal Inside Diameter- so, 3/4" INSIDE, not out. They tend to be pretty generous with that dimension, as it usually exceeds that by a fair margin. With the thickness of the wall (nearly 1/8") you'll find the outside diameter to be in excess of 1".
Go-Kart Maniacz
What is an axle bore? I am looking at a tire and it says the axle bore is 5/8 inch. Does this mean my live axle has to be 5/8 an inch?
